Rear Suspension (Bottom Out????)
Old Feb 21, 2020 | 09:45 AM
johnny_2X's Avatar
Hello All!
My wife's 2016 Acura ILX has a noise like the rear suspension is bottoming out. Especially when 2 people in back seat. Even sounds like rubbing noise when going around turns. Stock rims and goodyear tires in same exact config as stock tires. Anyone else experience this? I looked while changing brake pads and didn't see anything out of the ordinary.
Old Feb 21, 2020 | 09:55 AM
Miles ?
Old Feb 21, 2020 | 10:24 AM
Moussa Harouna's Avatar
Mine makes a huge thud noise when going over potholes. Had both rear suspensions changed under warranty, but still makes that noise even when there is no one in the back.
Old Feb 21, 2020 | 02:57 PM
johnny_2X's Avatar
80k...only does it when 4 adults total in car...sounds like passenger side only.
Old Feb 21, 2020 | 03:33 PM
maybe the bump stops is gone from there
Old Mar 1, 2020 | 08:38 AM
Pir8pete's Avatar
Automotive Tech
broken spring? just look under with a light, easy to see. or i could be the pivots are seizing
Old Aug 9, 2020 | 08:02 PM
skoobs's Avatar
hey, i had lots of noise coming from the rear
Lubed sway bar bushings, replaced sway bar end-links (moog) , drivers side shock was done replaced both shocks (kyb)
dead quiet
2013 2.4 / 110km or about 70k miles
Old Sep 27, 2020 | 01:43 PM
skarface's Avatar
I'm having the same problem. 95k miles. Rear tires are wearing quickly (15k miles) and fronts are still at 6/32. I changed the shocks in the rear. Still bottoms out when 3 people are in the back. Any ideas?
Old Sep 28, 2020 | 08:26 AM
visi_d's Avatar
time for some stiffer springs and heavy duty shocks lol
Old Sep 28, 2020 | 04:54 PM
skarface's Avatar
yeah definitely not exceeding any weight ratings. I can’t find a decent deal on springs. Any finds? I replaced my shocks with the kyb gas a just shocks so they should be good.
Old Sep 28, 2020 | 05:15 PM
poor wearing is indicative of an alignment issue.. have you done one recently? post the spec
Old Sep 28, 2020 | 05:41 PM
skarface's Avatar
I haven’t but the wear is pretty even and on the rear. I read something on the civic forums about the rear control arms causing excessive tire wear on the rear but I thought they fixed that already.
Dan01TL
Mar 16, 2007 03:19 PM
minkl81
1G TSX Problems & Fixes
Dec 12, 2006 09:06 PM
troba2k
Aug 17, 2006 09:35 AM
tyramail
Sep 30, 2005 04:27 PM
