Rear Hub Assembly replacement, VSA, Power Steering, ABS, Hill Assist LED's
Old Sep 2, 2025 | 08:11 AM
bionic_hip's Avatar
4th Gear
Hello,
I have a 2015 ILX (2.0 engine) Technically, it's my son's car...... Last week, I had to replace the R rear hub assembly. After installing everything, I am getting the following error codes:
Check Power Steering
Check ABS system
Check VSA system
Check Hill Start Assist
I ordered a new ABS sensor off of amazon......which ended up being the wrong sensor (too long, not the right connection). I tried cleaning the old sensor (wiped with IPA) and reinstalled. Still getting the same errors. I did order a new sensor that should be correct one. However, after reading older posts about those 4 LED messages, I'm wondering if it's something electrical? I have a OBD scanner but it is not showing any codes. So I'm at a loss.
Any help would be greatly appreciated.
Thank you in advance,
Old Sep 2, 2025 | 09:29 AM
Just for reference, the below is the OEM part number for the right rear abs sensor.
If any aftermarket ABS sensor was purchased, it should be based off & / or tie to that OEM part #.
I would keep it simple, for now, and wait until the the new sensor is replaced to make assessments / judgements on any remaining error lights.
In addition, if your OBD scanner does not have the functionality to read 'ABS' codes then they may not present themselves??
Good Luck
Old Sep 2, 2025 | 11:45 AM
bionic_hip's Avatar
4th Gear
Great, thank you.
As far as the OBD scanner, I guess it's possible it can't read the OBS code but I would have thought it would have at least displayed the Power Steering code?
Old Sep 2, 2025 | 01:05 PM
bionic_hip's Avatar
4th Gear
Any chance it could be the 70A multi fuse (EPS. -. ABS/VSA Motor. ABS/VSA FSR. WIPER. Main Fuse)?
Old Sep 2, 2025 | 01:41 PM
EasyLoveRDX's Avatar
It is almost certainly the ABS speed sensor. Very easy to damage them when taking them out, and it's one of the few sensors used by all three traction control/stability systems (ABS, TCS, and VSA).
Honda doesn't use standard OBD2 codes for the ABS system. You need a scanner that specifically says it can do Honda ABS codes. Foxwell NT-510 and Creader Elite are a couple that can.
Old Sep 22, 2025 | 03:18 PM
bionic_hip's Avatar
4th Gear
Update (a few weeks late):
Got the correct ABS sensor in, still have all the same error codes. So I'm still scratching my head on this one......
Nicknackzz13
Aug 3, 2018 11:04 AM
jcniest5
1/2G MDX (2001-2013)
Sep 24, 2017 06:38 PM
elproducto
Sep 17, 2012 10:42 AM
MOBB
Feb 15, 2011 11:00 AM
kjb219
May 19, 2005 10:19 PM
