what rear sway bar is available
Old Feb 19, 2013 | 09:48 AM
ck123's Avatar
my sister who knows nothing or cares for cars has a 06 tsx and i slapped in progress 22mm rear sway bar and she loves it. now she wouldnt want to drive a car without an upgraded one.
my girlfriend has a 2013 ilx 2.0 and i want to surprise her with one. im sure she'll appreciate the extra ride stability like my sister and i do. i drive an 01 integra with a 22mm rsb and she gets scared when i approach turns at higher than normal speeds but once the turns are over, she is amazed how well the car stays balance throughout the turn.
this leads to my questions:
1) is the frame strong enough to support a thicker rear sway bar or would i need a subframe brace?
2) what rear sway bars are available on the 2013 ilx? please mention the following:
brand
thickness
estimate cost
do i need to modify anything for it to fit or is it plug and play?
thanks! ***typed on phone, please ignore typos!***
Old Feb 19, 2013 | 10:24 AM
Trentimus's Avatar
brand
thickness
estimate cost
Apparently our rear end-links are "race car" strong. I couldn't tell you from personal experience..
Progress has a sway bar for the 9th gen Civic and Eibach has a sway bar for it.. both should work. The Progress one is supposedly better. Speed has the Eibach rear-bar and loves it. I think it's like <140 nothing else needed to go with it
Old Feb 19, 2013 | 10:42 AM
spdandpwr's Avatar
My bar rubs against the exhaust, so I'd hold off or get a 2013 Si rear sway bar. It's only 1mm smaller than the eibach and, if you buy the bushings and endlinks, has oem reliability. I may opt for that so I can get rid of the rattling.
Old Feb 19, 2013 | 12:13 PM
aaronnn's Avatar
weak. I just bought a 2012 si eibach sway bar.
Old Feb 19, 2013 | 12:20 PM
spdandpwr's Avatar
I think I may have installed it incorrectly. It otherwise fits perfectly....you can install the bars upside down apparently.
Old Feb 19, 2013 | 06:40 PM
ck123's Avatar
progress's website does not show any results for ilx or 12-13 civics
which year civics rear sway bar will work on the ILX??
Old Feb 19, 2013 | 08:45 PM
Trentimus's Avatar
I think it's the 8th generation. Like a 2011.. Goto redshifts website.
Old Feb 20, 2013 | 09:14 AM
neildam's Avatar
So buying a 9th gen OEM sway bar will work?
Old Feb 20, 2013 | 10:52 AM
spdandpwr's Avatar
9th gen 2013 (gotta be a 2013) si sway bar...yes
Old Feb 20, 2013 | 02:02 PM
neildam's Avatar
and what is the mm difference between the Tech/Dynamic/Si sway bars?
sorry i can't seem to find the ILX sizes!
Old Feb 20, 2013 | 02:05 PM
spdandpwr's Avatar
Just go to a honda parts retailer, order a rear sway bar, endlinks, and bushings from a 2013 Civic Si, install, and enjoy.
I can link to a thread with more info on another forum if you're still uncertain...inbox me.
Old Feb 20, 2013 | 02:21 PM
neildam's Avatar
I dont want to buy a rsb if for example the ILX is 17mm, the Si is 18 and the eibach is 19mm...
i've installed a few rsb's .. in my maxima + CSX.
so if anyone can state the different sizes it would be great.
Old Feb 20, 2013 | 03:54 PM
Trentimus's Avatar
Acura.com / 2013 Acura ILX
Front stabilizer bar, mm20: 2.0L & 2.4L
19: Hybrid
Rear stabilizer bar, mm14
Honda.com / 2013 Honda Civic Si Sedan
Stabilizer Bar (mm, front/rear) 21.0 / 18.0
Eibach official
Front: 24mm
Rear: 19mm
Progress RSB
22mm
Did you look or you just wanted me to do the work for you? lol
Anyways there you go!
Like Speed told me previously though.. the size isn't everything..
Old Feb 20, 2013 | 04:03 PM
spdandpwr's Avatar
There's a 4mm difference between stock ilx and civic si...plus it's an oem bar that won't wear out the endlinks. That's why I think it's worth it. It's also specifically made for the application, as opposed to the other bars.
Old Feb 20, 2013 | 04:13 PM
Trentimus's Avatar
Be hardcore and get a Eibach FSB and the Progress RSB
" as opposed to the other bars." what do you mean by that?
Old Feb 20, 2013 | 04:42 PM
spdandpwr's Avatar
The progress and eibach bars fit, but weren't made specifically for the ilx or 9th gen civic. So you run the risk of potentially having clearance issues with aftermarket suspensions or exhaust...nobody has had issues on the civic side of things, but we are guinea pigs at this point with the ilx...though I doubt it will be different.
Old Feb 20, 2013 | 05:06 PM
Trentimus's Avatar
Hmm.. TRUE. Did you ever try to adjust your bar?
Old Feb 20, 2013 | 06:10 PM
spdandpwr's Avatar
I'm going to do it when my exhaust gets installed
Old Feb 20, 2013 | 06:15 PM
Trentimus's Avatar
Did you buy one?
Old Feb 20, 2013 | 06:24 PM
spdandpwr's Avatar
Next month. Going to hack off the tip and weld a dolphin style tip. Invidia 70mm q300. Only $500 and very reliable for the price....best selling exhaust for the 8th gen civics
Old Feb 20, 2013 | 10:19 PM
Trentimus's Avatar
I am bent between waiting for GReddy and going full-race. The 3" is just something I am set on for the supercharger.
Old Feb 21, 2013 | 08:40 AM
spdandpwr's Avatar
3" is too loud for this car, I think. Plus I doubt you'll see more than a 5hp gain, and that's up top.
Old Feb 21, 2013 | 09:13 AM
neildam's Avatar
wow that's a big difference in the RSB in the ILX/Si. looks like i'll be heading to honda to order one. OEM quality+fit seems like a legit buy
anyone have one installed yet?
Old Feb 21, 2013 | 09:25 AM
spdandpwr's Avatar
They have on the civic threads...they've upgraded from the 15mm 2012 si bar to the 2013 si bar (18mm). Just remember to get bushings and endlinks too...you might need to get the brackets too.
Old Feb 21, 2013 | 09:28 AM
spdandpwr's Avatar
The only reason I'd prefer an aftermarket bar like the eibach is because it allows for stiffness adjustment.
Old Feb 25, 2013 | 12:50 AM
aaronnn's Avatar
you most definitely have it upside down.
Mine is on the right way, because I first had it upside down, it didn't look right.. It hit the exhaust. I flipped it around and it fit PERFECT.
All clearance, went for a ride, smoooooooootttthhhh. That rear end holds tight and no more flopping around. There is still some pitching in the front, but I'm hoping coilovers will take care of that.
All I know is, NIGHT and DAY difference. I drove 200 miles today before the sway bar install. Came home, installed the bar (20 minutes, with a quick drink break in the middle after I took off the stocker), went for a drive. I have it on the tighter/stiffer setting. It also doesn't hurt the harshness of the car either, actually its much more composed.
Anyways, $110 well spent. I can't wait for my commute in the morning.
Old Feb 25, 2013 | 12:53 AM
aaronnn's Avatar
I stiffer setting of the Eibach RSB is still not stiff enough. I can't get the rear to step out and rotate better. the eibach front and progressive rear sounds quite tempting.
Old Feb 25, 2013 | 08:25 AM
spdandpwr's Avatar
For a novice driver, the eibach on the stiffest setting should be plenty. Remember, most people don't know how to counteract oversteer on a fwd car. The bar was tough to install lol and it being upside down could be the reason why, ugh. Anyway, I told you all the bar would fit / work...psh, you can thank me now
Old Feb 25, 2013 | 08:38 AM
aaronnn's Avatar
Yeah, once I turned it around, bar went in without any problems. It fit right into place and everything bolted in smoothly. Car feels great. It should have came from factory like this. Slightly less floppy in the front too though
Old Feb 25, 2013 | 08:43 AM
spdandpwr's Avatar
Maybe install the front eibach sway and upgrade to the progress 22mm? The front sway bar is really hard to install though.
Old Feb 25, 2013 | 08:47 AM
spdandpwr's Avatar
p.s. I wish I got my sway installed professionally from the get-go. Now, I have to spend more time going to get it re-installed. Ugh, what a waste of time.
Old Feb 25, 2013 | 09:40 AM
aaronnn's Avatar
thats what I was thinking from that previous post.
Its not hard. Its just a bit more time consuming but still can be done with some jack stands and basic hand tools. But ive also worked at a maintenance shop for a couple years and also have a garage full of tools to do this on my own. also built the suspension myself in my track toy.
Old Feb 25, 2013 | 09:42 AM
spdandpwr's Avatar
Wanna help me install parts ?
I want to get an exhaust on next.
Old Feb 25, 2013 | 09:52 AM
aaronnn's Avatar
where in CT? i'm in north jersey, so I'm not too far from the border, but thats if you're in southwest CT area...
Old Feb 25, 2013 | 09:59 AM
spdandpwr's Avatar
Danbury CT, which is relatively close to southwestern ct
Old Feb 25, 2013 | 11:06 AM
aaronnn's Avatar
Damn, still an hour and a half away.. If you don't mind the drive, I can help you out with whatever installs on the car. All my tools, jacks, etc are all in my heated garage
Old Feb 25, 2013 | 11:10 AM
spdandpwr's Avatar
Um, I'm definitely swinging by. Coils or exhaust?
Old Feb 25, 2013 | 11:19 AM
Spirited Driver's Avatar
Aaronnn - You think this will mess with warranty? May want one of these.
Old Feb 25, 2013 | 11:27 AM
spdandpwr's Avatar
It puts more strain on the factory end links, so those would be out of warranty. But it shouldn't affect anything else.
Old Feb 25, 2013 | 11:28 AM
aaronnn's Avatar
easy and easy.
Coils, I may need to look for my spring compressor and ball joint puller. I should have it somewhere though. If not, we can always rent it from the Advance Auto down the block. probably take about 2 hours on factory settings. If you want to play around and adjust to make it lower/higher, it'll take an extra hour.
Exhaust should be cake. 1 hour - 1.5 hours max. although, I'm not familiar with this "downpipe" that we have on our cars, it's weird not having a full tubular header.. I would actually think it should be easier, but who knows, haven't tried it yet. If its a catback exhaust, I can't see it being longer than half an hour.
Matt - it has nothing to do with the warranty. I've had coilovers, sway bars, arm bars, cusco braces, big brakes, headers, exhaust, high flow cat, intake, tb spacers, camber kit, etc done on my TL and I still got warranty work done on my car. This was at Park Ave. I had to get my transmission and EGR valve replaced. They even gave me a TSX loaner for a week..
