Supercharged ILX??
Old Aug 19, 2015 | 11:28 PM
mmhdavid's Avatar
Supercharged ILX??
Has anyone supercharged or added in a turbo in their ilx?
And does anyone know a supercharger that will fit in the 2016 model?
Old Aug 19, 2015 | 11:44 PM
usdmJON's Avatar
We have two supercharged ILXs. Both have build threads here with ample info on their SC.
There is NO SC for the 2016. There isnt anything for the 2016 yet aside from maybe a set of coils.
Old Aug 20, 2015 | 12:05 AM
mmhdavid's Avatar
Can you direct me to the user's with the SC
Old Aug 20, 2015 | 12:26 AM
Thmanx's Avatar
The current SC ILX's are around because the engine layout and design is almost identical to the existing 2012-15 Civic Si K24 platform. Since there is apparently enough clearance in the engine bays between the two they fit just fine (not sure if they require different ECUs/ReFlash between the Si/2.4 ILX though)
As far as the '16 models. Those have more in common engine wise with the existing 4 cyl Earth Dreams Accords. And those models also are fairly limited in their aftermarket/tuning support (Hondata only recently offering units for them)
Its rather unsure if anything will come for the '16 anytime soon, but I feel as more Honda/Acuras use the new DI style engines it will eventually happen.
Hell even the wacky R18 civics now have tuning options (took a good 3-4+ years from the initial model year production though)... and now they even engine internals...
All comes down to demand. If there are enough consumers out there with newer ILX's that are looking for SC/ECU tuning options, eventually the aftermarket will support it.
Old Aug 20, 2015 | 01:05 AM
usdmJON's Avatar
They have threads in this section.
Old Aug 20, 2015 | 11:45 AM
OSUBeaver's Avatar
I have a supercharger in my ILX. Thread is called OSUs build or something. don't go on there much unless I change something but happy to help if I can. In the past, supercharger manufacturers have not made units for Honda/Acura cars with automatic transmissions very often (few expectations I'm sure) so not sure you will get one on the new ILX which has no manual option
Old Aug 31, 2015 | 08:00 PM
SlaammedILX's Avatar
To get the kraftwerks kit to fit perfectly, I had to bend a couple pinch welds, run slim fans, and cut a hole in the hood. Other than that everything bolts up with minor modifications.
OP: I don't post much on mine anymore since this forum is basically dead and everyone here thinks i'm mean or something. But if you need any suspension or technical advice, you can reach me faster though my IG or calling godspeed project.
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
rcs86
Aug 2, 2016 06:52 PM
marinrain
ILX
Oct 6, 2015 12:36 AM
Joe Avesyan
Sep 29, 2015 03:57 PM
ceb
ILX
Sep 27, 2015 10:56 AM
