NSX steering wheel
I mean youd have to look at the options the nsx wheel has verse the options the ilx has. Wouldn't want to lose features or have buttons that dont do anything.
Once that is figured out youd need to figure out how either wheel connects to the hub and if that is similar or can be retrofitted.
If the above 2 check out then all you need is money for an nsx wheel and a good electrician... Can you even buy something like that? I dont assume acura is just making nsx wheels. Id assume they are built for each nsx off the line. I could be wrong though.
If that all works my last question would be do you actually think a flashy nsx wheel would look good in yhe underwhelming ilx cabin?it would clash imo.
Once that is figured out youd need to figure out how either wheel connects to the hub and if that is similar or can be retrofitted. And keeps
Personally
Personally
Personally I like the steering wheel in my ILX A-spec. It has a nice thick grip to it and I like the smaller size of it. It fits the turnin radius of our car and the cabin size. And keeps the car feeling tight and nimble.
I'd stick to the much cheaper option- get your OEM wheel remade by EndlessRPM... they're a sponsor on here, and they can change any regular wheel, for the better. They can thicken up the padding, add carbon fiber, add alcantara (don't quote me on this one... but just ask them), add coloured stitching, etc.
At the end of the day, you can get a wheel that feels much nicer and looks much better, but still have all OEM buttons and functions work as necessary. Plus, going this route will likely be at least 3 times cheaper than buying an NSX wheel.
Edit: Decided to waste some time and check out OEM parts sites for an NSX steering wheel. This is the listing I found:
35880-T6N-A02
Switch Assembly, Steering Commander (Audio)
$117.46
36770-T6N-A02
Switch Assembly, Steering Commander (Cruise)
$114.77
77810-T6N-A80ZA
Module Assembly, Driver *NH900L* (Deep Black)
$781.08
77901-T6N-A00
Sub-Wire, Cable Reel
$20.10
78501-T6N-A82
Garnish
$167.87
78503-T6N-A80ZA
Grip *NH900L* (Deep Black)
$167.62
778515-T6N-A81
Guide, Cord
$47.00
78516-T6N-A81
Bracket, Garnish Support
$95.51
78518-T6N-A82ZA
Cover, Body *NH900L* (Deep Black)
$33.00
78560-T6N-A82ZA
Switch Assembly, R Paddle Shift *NH900L* (Deep Black)
$77.23
78565-T6N-A82ZA
Switch Assembly, L Paddle Shift *NH900L* (Deep Black)
$77.23
90134-S6A-A80
Bolt, Hex (6X23)BOLT, HEX. (6X23)
$2.23
90161-TX4-000
Bolt, Steering Wheel (M18X1.5 G)
$9.80
90178-SNB-N61
Screw, Tapping (3X8) (Po)
$0.62
93893-04010-08
Screw-Washer (4X10
$0.66
93913-24420
Screw, Tapping (4X16) (Po)
$0.44
$117.46
36770-T6N-A02
$114.77
77810-T6N-A80ZA
$781.08
77901-T6N-A00
$20.10
78501-T6N-A82
Garnish
$167.87
78503-T6N-A80ZA
$167.62
778515-T6N-A81
Guide, Cord
$47.00
78516-T6N-A81
$95.51
78518-T6N-A82ZA
$33.00
78560-T6N-A82ZA
$77.23
78565-T6N-A82ZA
$77.23
90134-S6A-A80
$2.23
90161-TX4-000
$9.80
90178-SNB-N61
$0.62
93893-04010-08
Screw-Washer (4X10
$0.66
93913-24420
$0.44
Didnt want to do the math so I just throwing it all in my cart and hopefully not missing anything we get...
- Subtotal Amount: $2,546.98 Though they had the first two assemblies listed twice at 117/114 each not sure what that's about.
