New ILX Stalling
Old Oct 23, 2013 | 06:24 AM
harnedke's Avatar
5th Gear
New ILX Stalling
Hi my name is Kyle and I have been a member for awhile, but mostly lurk on here and don't really post. I previously had a 2004 CGP TSX and just picked up a 2014 BWP ILX a little over 3 weeks ago and it is already is having issues with less than 800 miles.. 3 times now it has stalled at a stop light and I have had to shut it off, wait several seconds to minutes until it would turn back on which has caused me to almost be in several accidents. I took it to the dealership and they took it out for a test drive to see if they could reproduce the issue and thankfully it happened to their tech. They said it might be the EGR valve so they replaced it and have been driving it to see if it has any more issues. If everything goes well I should get the car back today.
Has anyone else experienced this or know what the issue might be? I trust the dealership/ the car is under warranty, but I wouldn't mind getting other peoples thoughts.
Old Oct 23, 2013 | 06:36 AM
since its a new car, most likely not many people have experienced this.
I would rule out a dirty EGR valve, but that doesnt mean the EGR valve was faulty.
if they are just throwing parts at it, they dont know whats wrong...
Old Oct 23, 2013 | 07:07 AM
harnedke's Avatar
5th Gear
That is kind of what I thought, I would rather them take their time and figure out what the problem is than to "think they know" and slap on random parts. I don't mind the RDX they gave as a rental, but I wish it still had a turbo
Old Oct 23, 2013 | 07:10 AM
what kind of gas are you putting in her?
Old Oct 23, 2013 | 07:20 AM
harnedke's Avatar
5th Gear
Premium (91) like the Owner's Manual calls for. However, my father did put 89 in it once, but Acura claims that should not have been an issue and it is safe to run 89 all the time.. I don't agree with that one bit and think the lower grade of fuel might have helped contribute to the issue, but considering it has happened on more than one occasion and on both types of gas I am not sure what is causing it.
Old Oct 23, 2013 | 07:24 AM
^right, stick with 91 or higher.
it could be just a bad case of gas.
any weird vacuum noises when these stalls would occur?
if yes, a vacuum hose could be knocked off, or something...
Old Oct 23, 2013 | 07:45 AM
harnedke's Avatar
5th Gear
Honestly I am not sure, I have always had the radio on and the a/c going so I haven't been able to tell.
Old Oct 23, 2013 | 10:57 AM
4cruizn's Avatar
That's a scary thing to have happen. I haven't experienced anything similar, but please do keep us posted on how the issue is corrected. Thanks for sharing.
Old Oct 23, 2013 | 02:18 PM
usdmJON's Avatar
Is this an auto or manual ILX?
I started out using 91 for the first maybe 5 months. I hit a rough couple months and I started using the lower grade. Since then I have actually seen an increase in gas mileage but no stalling issues. This is in a 2.0 btw.
Good luck!
Old Oct 24, 2013 | 05:49 AM
harnedke's Avatar
5th Gear
Picked up the car last night after Acura had it for 3 days and they said since they replaced the EGR valve and filled it with 91 and drove it, it had not had any repeat episodes. They are "fairly confident" that it was a faulty EGR valve from the factory and said to bring it back if there are any other issues.
Good luck!
The car is a 2.0 automatic. That is strange that you have seen an increase, I would have thought the opposite and a rougher ride due to the fuel burning faster and the engine tuned for a slower burning fuel.
Old Oct 24, 2013 | 06:44 AM
^there's TOO many variables for that gentleman to pinpoint his lower octane fuel mileage increase claim...
unless he has a spreadsheet that shows his same route, his same driving habits, his same time idling at redlights, in the same weather at the same station....just too many variables..
Old Oct 24, 2013 | 01:56 PM
usdmJON's Avatar
All I know is for the first roughly 5 months I was using the medium grade octane level.
During this time I was getting around 24 mpg.
I started using a lower octane grade some months ago and have seen it climb to nearly 28.
I then put in an aftermarket intake and saw a decrease in gas mileage that I associated with my increased heavy foot.
Im now seeing just under 27 average while using this lower octane.
I would say the intake increased my mpg but initially I saw a decrease and my increase in MPG was witnessed about 2 months prior to the intake install.
Old Oct 24, 2013 | 02:11 PM
nj2pa2nc's Avatar
it's a car-drive it
that could go for someone that states they use regular once or twice and saw a drop in MPG. Lots of variables. Used premium for about 7,000+ miles. Switched to regular and never went back. Excellent gas mileage with more than enough power for the type of driving I do (no curb hitting)
Old Oct 24, 2013 | 02:13 PM
you forgot to add the crabs in there.
but you're exactly right.
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
rcs86
Aug 2, 2016 06:52 PM
marinrain
ILX
Oct 6, 2015 12:36 AM
ceb
ILX
Sep 27, 2015 10:56 AM
prbori
Sep 27, 2015 01:37 AM
