Has Anybody with Disabled ANC noticed Louder Cabin Noise?
I have not noticed any louder cabin noise.
How would I go about temporarily removing the glove box? I'm assuming there are screws involved.
This is my first self bought new car and I really don't want to screw it up.
Thanks again for the help.
Im in the same boat as you mang.
There are a few screws holding the glove box in.
I unplugged my ANC without completely removing the glove box.
I popped the silver accent piece off. Its held on by a few tabs that just need a little work to get out. Once that is off you will see the glovebox is held on with some screws and 3 plastic prongs sticking out from the dash.
I just pulled the top of the glove box out of the prongs (FINESSE!!). I used one hand to pull the glove box down about an inch. Then stuck my hand as far in as I could and felt around for the ANC plug. I used that hand to open the connector and my other hand to just pull on the cable to pull the connector free. I just let it hang, closed the glovebox up and called it a day.
If you're not confident enough to do it yourself see which shops around you will do it for like 30 minutes labor. Easier to do but I understand your caution.
rockyboy
01-25-2016 06:00 PM
