Hardwiring blackvue power magic pro - which fuses to tap?
Old 01-18-2019, 09:17 PM
InSug No's Avatar
Installing power magic with dash cam
If anyone has done this install ilx, where did you tap the red and yellow wires under the dash fuse box?
Red is ACC - provides power when ignition on
yellow is goes to a fuse that's always on.
Black is ground
Old 01-25-2019, 10:31 AM
Automotive Tech
Pir8pete's Avatar
just use a volt meter and go find what you need in the fuse box bro. it's easy whats what I did. there are multi points that provide this, and use tap-a-fuse to make thing even easier nuff said
Acura604
12-29-2017 01:17 PM
Acura604
12-02-2017 01:43 PM
Acura604
20
08-05-2017 12:55 AM
JnC
02-18-2014 11:49 PM
Quick Reply: Hardwiring blackvue power magic pro - which fuses to tap?
