*REVIEW* Snap n Go Blackvue hardwiring kit via OBD2 port
2021 RDX A SPEC
This is a great alternative to powermagic!
no need to mess with fuses and all that extra wiring crap and grounding....
just plug it into the OBD2 port of your car!
I tested it with blackvue models: DR380G, DR3500 and DR650S
all worked great. Test car: 2016 CIVIC EX
when the switch is set to ACC mode, the unit will power down the blackvue after 5mins once ignition is cut.
when the switch is set to parking mode, the unit will run the dashcam but will shut it down when battery level drops below 12V.
https://www.7daycam.com
step 1: find your obdII port
step 2: plug in the SnapNgo unit
step 3: run the wiring up your a-pillar/roofline - hide it well...
step 4: attach power lead to dashcam
step 5: set the SnapNgo to acc and turn on car
step 6: flick switch to parking mode if needed
