Accessory Mode
Old Dec 1, 2017 | 04:22 PM
MHarnois's Avatar
Accessory Mode
When parked, how can I turn off the engine while keeping the accessory mode on to keep on listening to the radio? I've found some old threads on this topic but nothing current. The common suggestion is to shut off the engine while the transmission is in neutral but on my 2018 the radio stays on when I turn off the engine from neutral but it shuts off as soon as I slide the transmission to park. They surely don't expect you to leave the car in neutral, do they?
Old Dec 1, 2017 | 04:47 PM
MHarnois's Avatar
I found my answer. Did you know that in addition to our Owner's Guide, Acura also has an Owner's Manual online? The Owner's Manual has this nifty diagram which confirms that, for US models at least, putting the car in Park while in accessory mode will turn off the radio. The Owner's Guide doesn't have that information. Canadians might get to enjoy their radio while in Park, I don't know.
Old Dec 1, 2017 | 05:30 PM
jcross1231's Avatar
Touring
The owner's guide has the information in text form under the heading "Changing the Power Mode". There are two modes available without the engine running: "Accessory" and "On". It's unfortunate the car takes so long to boot up when cycling the power. Acura should have installed more processor resources.
There is a 3rd manual available for the Nav system. All 3 are downloadable online.
Old Dec 2, 2017 | 06:07 AM
Gadgetjq's Avatar
Inveterate Tinkerer
MH,
With my '17 RDX the owner's manual (along with the nav manual and owner's guide) are on a CD that was included in a leather bound info packet provided by the dealer. In addition, original owners of Acura vehicles can order a hard copy of all manuals and, of course, we can download .pdf copies of all the above. The full manuals offer a 'lot' of information you won't find in the quick start guide.
Owners really should spend some time sitting in the vehicle with the full manual going through it page by page to identify (otherwise hidden) features.
Cheers!
Old Dec 2, 2017 | 10:38 AM
MHarnois's Avatar
Originally Posted by Gadgetjq
MH,
That's odd, the CD included with mine is titled "2018 Warranty Information" and that's all it has on it, no manuals.
Old Dec 4, 2017 | 06:37 AM
Kirill's Avatar
Try pressing and holding shift lever release button when pressing the start/stop button when transmission is in park. This works on my 17 RDX and 14 MDX
Old Dec 4, 2017 | 01:51 PM
jcross1231's Avatar
Touring
With the engine running or turned off? All it does for me with the engine running is give me the fast beep error message. With the engine off - and not applying the brake - it goes into accessory mode.
Old Dec 4, 2017 | 09:06 PM
MHarnois's Avatar
It works as long as I keep holding the shift lever release button when stopping the engine but radio shuts off as soon as I let go of it so I guess it doesn't really work on the '18 models.
Old Dec 5, 2017 | 12:56 AM
jcross1231's Avatar
Touring
That's the way it works on the '16 models and probably the '17 models, too. It would be nice to be able to shut the engine off without going through the tedious reboot cycle to get the accessories going again.
Old Dec 6, 2017 | 06:05 AM
Kirill's Avatar
With engine running, transmission in park and release button pressed when I hit start/stop button my 17 RDX goes to accessory mode without losing Bluetooth connection or radio. Just tested again yesterday and works with foot on the brake and without. The car doesn't shut off when I let go release button, stays in accessory mode.
Old Dec 6, 2017 | 09:39 AM
RDX-Rick's Avatar
Thanks for that tip. Up to now I had been turning off the engine while still in drive, and then moving to park, but your method is much better.
I am in Canada, and I was wondering if you were as well. The section of the owners manual in post #2 shows a notation that US vehicles behave differently.
Old Dec 6, 2017 | 11:02 AM
jcross1231's Avatar
Touring
I just double checked this again several times. On my '16 Advance, accessories shut off when the release button is let go. Hmmm...
Old Dec 6, 2017 | 11:33 AM
Kirill's Avatar
Yes, I'm in Canada as well, I missed the part in the manual that US cars behave different. Maybe this is the reason that it doesn't work for them. But this works exactly the same on my 17 RDX and 14 MDX, both base models Canadian editions.
Old Dec 6, 2017 | 11:43 AM
MHarnois's Avatar
That pretty much settles it then. Canadian cars can use the shift lever button trick but U.S. cars can't.
Old Dec 6, 2017 | 02:35 PM
jcross1231's Avatar
Touring
Wonder why the differentiation? The Canadian method is a lot more convenient. I just re-confirmed on my '16 US Advance that the system dies when you release the shift lock after shutdown.
