This is the first MT car I've driven with a hill holder...
Old Jun 1, 2013 | 03:18 PM
Shigatsu's Avatar
It keeps throwing me off.
How many of you actually let off the brake pedal and rely completely on it- at least I'm assuming it will work that way.
The main intersection outside of my house is a hill, thus I'm nearly always stopping on a hill at the red light. I still haven't gotten used to it. I keep launching the car. My problem is I do it all quickly by reflex (I also have a bad habit of letting go of the brake THEN putting it into first) and usually the car is rolling backwards but because it isn't, I have too much rpm when it engages.
I guess I have to train myself to fully press the clutch, put into first, let off the brake, then slowly gas it up. Every car I've driven up to now, I always have it in neutral, let off the brakes, put into first and then zoom off quickly. It always worked for me until this car.
Old Jun 1, 2013 | 03:19 PM
Shigatsu's Avatar
Oh and anyone know if its possible to turn it off? Heh.
Old Jun 2, 2013 | 12:57 AM
4cruizn's Avatar
It'll only hold you for a second or so; you can't rely on it to keep you there any longer than that. I alternate between a couple different MT vehicles and the ILX is the only one with hill assist, so it catches me offguard too. While I appreciate the help sometimes, I also like being able to use my fancy footwork from time to time instead of relying on it. To my knowledge there's not a way to deactivate it.
Old Jun 2, 2013 | 08:04 AM
SlaammedILX's Avatar
I just throw it in first gear and lightly let off the clutch so it balances it self out at a stand still with my other foot ready on the gas pedal. Just my 2 cents
Old Jun 2, 2013 | 01:01 PM
usdmJON's Avatar
I doubt THIS will help but it may shed some light that it is possible.
HSA Off
If you wish to turn off the HSA system, follow this
procedure:
1. Start with the engine off and vehicle in PARK (automatic
transmission) or NEUTRAL with clutch out
(manual transmission) with wheels straight. Apply parking
brake on manual transmission vehicle.
2. Start the engine.
3. With the engine running, the brake applied, and the
clutch out, rotate the steering wheel a half a turn counterclockwise
from center.
4. Press the “ESC Off” switch four times within twenty
seconds.
5. Rotate the steering wheel a full turn clockwise (half
turn clockwise from center).
6. Cycle ignition switch OFF then ON.
7. If the sequence was completed properly, the “ESC
Malfunction Indicator Light” will blink several times to
confirm HSA is off.
Steps 1-7 must be completed within 90 seconds to turn off
HSA. Repeat steps 1-7 to re-enable HSA functionality.
^That is from a Jeep forum. Try that or search your manual to see if the ILX has its own way. Seems possible though.
usdmJON's Avatar
HSA stands for Hill Start Assist... there is the technically term if you needed it for a search.
Old Jun 3, 2013 | 11:04 AM
spdandpwr's Avatar
Hill start assist only activates when you press the brakes on a hill...If you don't depress the brakes, it doesn't turn on so you can just balance the car with the clutch and gas (bad idea) or watch the lights and let go of the brake a little early before the light turns green. I've gotten used to it...guess that's what 12k miles of driving does
Old Jun 4, 2013 | 02:11 PM
Spirited Driver's Avatar
Can anyone confirm this works on our car?
Old Aug 12, 2013 | 02:06 PM
bjohnston115's Avatar
Bump on this... How the hell do i turn this amateur feature off. I can understand how this would be helpful for a person new to a manual transmission but when you know how to drive it hurts the car. I sit there burning up with clutch because the car holds on the brakes but i am trying to move.
Old Aug 12, 2013 | 02:43 PM
Colin's Avatar
Both our CR-Z and ILX have this feature. It's caused me to stall once or twice. These days, I just count "thousand one..." and let the clutch out. Easy to adapt to it after a short while.
Old Aug 12, 2013 | 03:37 PM
usdmJON's Avatar
Im sure someone learning on an ILX will find hill shifting much easier. Someone that is used to compensating for the incline will have to adapt. That normal with pretty much all technology. Imagine being your grandpa adapting to how easy technology has made life.
Old Sep 5, 2014 | 10:47 PM
paperboy42190's Avatar
I just wanted to double check, the hill assist is only for the stick shifts right?
Some hills are steep enough to make an automatic roll back in drive.
Old Sep 6, 2014 | 12:52 AM
usdmJON's Avatar
They all have it paperboy.
Old Sep 6, 2014 | 02:44 AM
destroying your clutch in the process
peti1212
ILX
22
Jan 5, 2022 05:14 PM
tonio
Feb 5, 2019 05:43 PM
spoiler900
5G TLX Photograph Gallery
Sep 11, 2015 09:39 PM
darknite123
Integra
Aug 30, 2015 03:00 PM
ptbarnett
3G RLX (2013+)
Aug 30, 2015 12:39 PM
