Diego's Build Thread
Old Oct 16, 2015 | 01:27 PM
DiegoxRivera's Avatar
7th Gear
This is my first acurazine post, I currently have a 2015 ILX 2.4 that's about a year old now. I recently ordered a set of Weds Kranze ERM 3-piece wheels, 18x8 + 45, 18x9 +45. Wheels probably wont be here until early November and probably won't mount for long since winter is right around the corner. I've had the car stock for year now, but now I'm deciding on starting mods. Once winter passes i'm hoping to have coilovers and wheels installed. Still indecisive between D2 racing RS coilovers and Godspeed MonoRS coilover systems, any thoughts on which to choose? Also plan on ordering Injen air intake, and full race DP + Exhaust, by spring.
Old Oct 16, 2015 | 01:31 PM
7th Gear
Here's a picture of my car, the wheels I ordered, and a quick photoshop on my phone of roughly what the wheels would look like. Diego's Build Thread-img_6622.jpg Diego's Build Thread-img_6636.jpg Diego's Build Thread-img_6679.jpg
Old Oct 16, 2015 | 02:25 PM
2012wagon's Avatar
Nice
Old Oct 16, 2015 | 02:28 PM
usdmJON's Avatar
Sweeeeet.
Old Oct 18, 2015 | 10:24 AM
Jorgee's Avatar
Nice start to your build!
Old Oct 19, 2015 | 11:32 AM
7th Gear
Question
thanks guys for the compliments! But does anyone think they can give me some help on which coilovers to choose between the godspeed monoRS and D2 coilovers?
Old Oct 19, 2015 | 11:47 AM
Jorgee's Avatar
If you check out my build thread I'm on Godspeed mono rs the 32 way dampening ones.
Old Oct 19, 2015 | 12:07 PM
7th Gear
I'll check it out, thank you
Old Oct 21, 2015 | 11:03 AM
4cruizn's Avatar
Very nice! Looking good.
Old Oct 22, 2015 | 05:08 PM
7th Gear
thank you.
I think I decided on the Godspeed Mono RS Coilovers. hopefully I'll order them sometime in November/December. Does anyone know if someone has the hookups or could get a deal on them?
Old Oct 22, 2015 | 05:16 PM
usdmJON's Avatar
thank you.
Try SlammedILX or AarontheAsian on IG. Not sure if he can or would hook it up but Im sure he'll have great pricing!
Old May 1, 2016 | 02:16 PM
7th Gear
Well, I went with the Godspeed coilovers and they went on about a week ago with the oem wheels. Today I mounted the other wheels, didn't see any contact when putting them on but once the car got lowered and I started to back out of the garage I heard a slight rubbing noise and they ever so slightly hit the front struts. Debating now on what size spacers to go with, between 5-10mm. Here are some pictures before I put the oem wheels back on.
Old May 1, 2016 | 02:17 PM
7th Gear
also need to even out the coilovers, the back are a bit lower than the front
Old May 1, 2016 | 04:45 PM
usdmJON's Avatar
Looking good man! Id say go 5mm spacer since most agree that 10mm is just too much unless you pick up 10mm spacers with pressed bolts.
If its just the front Id say go with 10mm spacers in just the front to get away from the strut and also even out a little of the stagger you have from the 8 and 9in wheels. It'll still be staggered by about 15mm.
If you want to go all four corners with spacers Id say 5mm since Im not sure how close the rear wheel is to the fender. 10mm or more may start rubbing fender.
I have 8in wide wheels on 25mm spacers and the rear rubs a lot. I think if you went about 10mm youd be about 5mm away still but cant say 100%.
Old May 5, 2016 | 08:41 AM
Triscuit's Avatar
Are you running the 18x9 in the rear? I'm currently running a 18x8 +44 in the front with a 20mm spacer (w/ attached studs). I rub only on hard bumps. Our ILX can take a 18x9.5 +35 in the front and rub very lightly. It will not touch the front struts either.
Have you started on the performance mods? You're close in VA (I'm in MD). My mods are a HPS intake arm, removed resonator, K&N drop in filter, RV6 catted down pipe, and Hondata Reflash. Maybe we can meet up to see how loud the catted down pipe makes the car before you purchase an exhaust. I do plan on getting the DC Sports turn down exhaust and an Injen SP Cold Air intake.
Old May 11, 2016 | 10:02 AM
4cruizn's Avatar
Looks great!
AZuser
Money & Investing
48
May 7, 2019 07:37 AM
jdmjess
4G TL Problems & Fixes
Feb 19, 2018 11:26 AM
AllDay1214
ILX Performance Parts & Modifications
37
Jul 15, 2017 04:11 PM
oVerBoost
Feb 16, 2016 03:38 PM
dlevesque
Oct 30, 2015 06:13 PM
