Coolant Leak :(
Old Jul 2, 2015 | 09:22 PM
mvidal6's Avatar
'15 ILX CBP 2.4
Coolant Leak :(
Guys my jack got stuck under my car the front lip trapped it being unable to move the jack, i lifted it up and then coolant (blue) started leaking from the push pins and its still leaking as we speak like droplets.
Old Jul 2, 2015 | 10:24 PM
mvidal6's Avatar
'15 ILX CBP 2.4
I opened the engine underbody panel and theres nothing leaking from anything, radiator hoses are fine although from the front i can inspect that the radiator from the center has been pushed vertically forward. Still no leak
Old Jul 3, 2015 | 12:01 AM
mvidal6's Avatar
'15 ILX CBP 2.4
The abundant source of leak is coming from this hole but im unable to see inside of it. All hoses look fine and the radiator plugs on the bottom look in tact.
Old Jul 3, 2015 | 02:05 AM
usdmJON's Avatar
Sounds like when you jacked it up again it wasnt under the reinforced jack point and you pushed your radiator up. Much like crab man did.
Only advice I can give is to take it in to a shop you trust or the dealer. Unless you can take the front of your car apart and replace the radiator and possibly any supports/hoses.
Good luck man.
Old Jul 3, 2015 | 09:20 AM
mvidal6's Avatar
'15 ILX CBP 2.4
Yeah when i lowered the jack it wouldnt come out all the way and it got stuck under the radiator, you can see in the picture it is shifted up from the center.
Going to take it to a shop and put it in a lift to see more. Im hoping its something simple and if i have to replace my radiator i might as well go for a mishimoto type right?
Old Jul 3, 2015 | 11:24 AM
mvidal6's Avatar
'15 ILX CBP 2.4
Nice well my radiator is punctured and fucked that needs to be replaced it is literally shifted up and the frame as well.
Old Jul 3, 2015 | 11:42 AM
mvidal6's Avatar
'15 ILX CBP 2.4
If anyone can help me find a radiator for a 2015 2.4l, cause the ones im finding say it doesnt support a 2.4l and they are all 2013 and 2014 models.
Mike734
Dec 10, 2021 01:25 PM
IBankMouse
Jun 13, 2020 12:53 PM
Avenger411
Oct 11, 2015 03:53 PM
steve
Sep 30, 2015 09:23 PM
Boraxo
1/2G MDX (2001-2013)
Sep 29, 2015 04:35 PM
