Anyone know how to compression test an ILX?
Old Apr 30, 2015 | 07:24 PM
trexter's Avatar
I can't crank the engine over due to the push button start. Pushing the start button does nothing.
Unplugged the ignition coil packs from the spark plugs
Removed fuel pump fuse
Removed ign coil fuse
Removed the spark plugs
Put in compression tester
Wanted to do the test to serve as a baseline to monitor engine health over time. In a friend's S2000, we did the same thing but pushing the start button still turns the engine over.
Any ideas?
Old May 21, 2015 | 12:22 PM
marsman328's Avatar
6th Gear
dont remove the fuel pump fuse or ignition coil fuse, just unplug coils and unplug clips on injectors.
Old May 21, 2015 | 12:24 PM
musty hustla's Avatar
post the results
Old May 29, 2015 | 12:23 PM
trexter's Avatar
thanks, compression test worked out nicely
Cyl 1 to 4: 230, 225, 225, 230
Im happy with the results
MrHeeltoe
20
Feb 23, 2023 01:54 PM
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
ceb
ILX
Sep 27, 2015 10:56 AM
