Adding spacers after alighnment....
Old May 29, 2015 | 12:34 AM
kukio's Avatar
Will adding spacers after getting alighnment throw the alighnment off?
Old May 29, 2015 | 07:31 PM
AZuser's Avatar
_
No. Spacers will not change the alignment angles of the wheels/tires.
The same goes for when getting new wheels, new tires, rotating tires, or replacing brake pads and rotors.
Old May 29, 2015 | 09:45 PM
kukio's Avatar
Thanks man. Im hoping .5"spacer will be enough to bring that rear tires out. I shouldve went with 8" wide.
Old May 30, 2015 | 01:57 PM
usdmJON's Avatar
Make sure you buy spacers with pressed in studs if you go that wide.
If you are interested i do have 15mm spacers from garageline. They sell for about 100. Ill do 70 plus shipping. They were on my ilx but took them off when i got my 8in wide work wheels.
Old Jun 1, 2015 | 07:20 AM
aomechmarine's Avatar
Dude you need at least 25mm spacers for the rear Id recommend the either garage line or the Hand R wheel spacers I have. You will be be flush in the back. If you get Jon's 15mm spacers for the front, that would also work. I have 25mm spacers all around on the stock 17x7 wheels, front is pretty flush to the fender, rear could push out a tad bit more, trust me on this. If you want the front to stick out more, then just get 25mm all around.
Old Jun 1, 2015 | 03:18 PM
usdmJON's Avatar
My bad. I have 20mm for sale. Not 15mm.
Id go 20mm up front and 25mm rear. Thats what i was going to do before i got new wheels.
RLX-Sport Hybrid
3G RLX (2013+)
27
Dec 7, 2018 12:11 PM
Jul 16, 2017 07:33 AM
CL-S progression 01
Jan 26, 2016 04:15 PM
Froid
Sep 27, 2015 06:16 PM
