Adding spacers after alighnment....
No. Spacers will not change the alignment angles of the wheels/tires.
The same goes for when getting new wheels, new tires, rotating tires, or replacing brake pads and rotors.
If you are interested i do have 15mm spacers from garageline. They sell for about 100. Ill do 70 plus shipping. They were on my ilx but took them off when i got my 8in wide work wheels.
Dude you need at least 25mm spacers for the rear Id recommend the either garage line or the Hand R wheel spacers I have. You will be be flush in the back. If you get Jon's 15mm spacers for the front, that would also work. I have 25mm spacers all around on the stock 17x7 wheels, front is pretty flush to the fender, rear could push out a tad bit more, trust me on this. If you want the front to stick out more, then just get 25mm all around.
My bad. I have 20mm for sale. Not 15mm.
Id go 20mm up front and 25mm rear. Thats what i was going to do before i got new wheels.
