1/4" air gap on the double wall tip, but I put a thin sheet of reflective fiberglass shield just in case. I shot some temps on the tip and idling in 95 degree weather it only got up to about 109F.
A bit louder with a nice mellow sound.
Working with RV6 to get us a bolt-on pre-cat delete pipe.
This should open up using axle-backs that fit the 2013-2015 Civics.
Either work for me. First one is fap worthy. I believe it possible to trim out the black section in the bumper and run a dual tip up there. Though the piping may be smaller to make it all fit... that wouldnt really matter as you're far enough from the mani for a bottle neck at that point to really cause any reduction in performance. Nothing too noticeable anyway.
Bottom one I imagine would be not too hard to run 2.5-3in piping across to the drive side. Bottom one looks like Aaron's until he swapped the quads for the single outlet.
I'd do something like this if there would be a grill add-on available for the ILX. Idea is off of the BMW M4. Saw one on the street the other day and I really fell in love with its rear.
Your first picture with the quad pipes through the reflector area looks the best. It makes the car look wider
The m3/m4 style doesn't work on the ilx. That style works good on the vette and m3/m4 as those cars have wide rear end. Doing that on ilx makes it look very narrow butt
Would these fit on my '16 ILX like how you say the 2013 Civic SI axle-back fits like OEM ?
