Where to get wallplates?
I need to run wires to the rear of my living room and I want to put a wallplate back there with two rear speaker connections and a subwoofer connection. The subwoofer will be using the standard RCA/coax connection. Any idea where I can get this?
Originally Posted by TXXXX
Lowes, HD stock them also.
In our last place I got them from there. Nice and easy b/c I bought an extra one which I ended up needing to return... so didn't need to mail anything back... just drive back and return it
Similar question. I burried some boxes containing speaker wire in a new wall a couple months back (wasn't ready/sure if i was going to put speakers there)...
Well, I lost the drawing with measurements on where I put them... what's an easy way to find the shit? Stud sensor doesn't work.
You can get a good educated guess of the stud location, then use hammer to tap a long finished nail therough the drywall. You will know when you hit a stud.
Oh I know where the studs are, problem is I forgot which studs I put the boxes on and how high they were
Yeah, i was going to go the pilot hole route... just figured I'd see if ya'll had any better ideas
How did you run the wire? Can you find it from the attic and get a general idea which studs they are between?
You said a stud finder didn't work - are they plastic boxes? If they are metal, the studfinder should help you find them - mark out your studs, then move it all over the place in between them till it picks something else up.
Last option is to x-ray the walls.
^-- hmm. good idea. tad scary... but good idea.
Any risks (besides electrocution
)? Fire and such I mean?
You're pretty SOL though...
The Dougler
Oct 15, 2009 07:16 PM
I had to goto HD for something else and I picked up everything that I needed for the wallplates.
