PIP Problem
Old May 8, 2006 | 05:05 PM
Acuraluvr's Avatar
Spinnin them beats
PIP Problem
I am having a problem fixing the pip function on our Plasma TV with our Comcast Box. How do you use the function?
Our Vizio, when pip is on, can only use pip is the image is from another source; how do cable boxes use the pip function? when i try to use pip or press the picture in picture button on the given comcast remote, the box does nothing.
A Primitive solution i though was to get a splitter and split the cable before it goes to the cable box and hook the second wire to a VCR/DVD recorder and switch channels using that for the second input. However, the splitter might disrupt the signal for On Demand and regular channel switching.... Any thoughts or solutions?
Old May 8, 2006 | 05:58 PM
Moog-Type-S's Avatar
The sizzle in the Steak
Your cable box is your tuner.
PIP is using the TV's tuners.
Thus no PIP from one cable box source.
Old May 9, 2006 | 03:20 PM
Acuraluvr's Avatar
Spinnin them beats
i know but on the cable box, there is a pip button... when pressed, nothing happenes
Old May 9, 2006 | 03:27 PM
doopstr's Avatar
I think that only works with the DVR. The DVR has two tuners.
Old May 9, 2006 | 03:59 PM
juniorbean's Avatar
This is correct. We have two cable boxes in the house.... one is an HD-DVR, one is the regular HD box. Remote is the same on both, but the PIP only works on the DVR b/c it has two tuners as doopstr mentioned.
Sounds like you have a regular cable box...
SidhuSaaB
May 30, 2020 12:40 AM
Fool
Mar 10, 2016 08:42 PM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
