120mhz + BR= WTF?
120mhz + BR= WTF?
Anyone have a 120Mhz refresh rate flat panel TV? Or watch a blue ray on this? HOLY CRAP, I watched a blue ray on one of these TV's recently and the picture is unbelievable. Actually, not in a good way IMHO. We watched irobot and the graphics really stood out and you could tell what was fake/real EASILY. It almost was like watching a movie directly though the camera, completely unprocessed. I don't know how to describe it, but I almost wanted to "de-tune" this feature if it's possible. Anyone else?
Unofficial Goat
The Third Ball
Received 5,105 Likes
120hz is for sports and video games. Turn it OFF for movies.
I really wish manufacturers were clear about what is for what.
I found this out playing Rock Band, and it was horrible!
The Box
It most definitely takes some time getting used to 120......the first few movies I saw I felt like it was almost live. I like it now though and I can't watch regular tv's anymore.
If it's for sports broadcasted at 720p, then how does it look like? Also, there are 240mhz tv's out now, how does that look like broadcasting 720p TV (sports or movies)?
After searching on this phenomenon, and talking to some pro installers, they all say to disable it for BR movies. So hope you're not too used to it.
The Third Ball
All the hertz bs is marketing crap from people. then people get home, dont know how to set up their TVs and then wonder why the image sucks, and then complain is terrible.
The Third Ball
Big Block go VROOOM!
OK here's a stupid question, can an LCD panel have more than one refresh rate? I thought they actually only had a single native refresh rate and dealt with signals that differ from the native rate via multipliers. If this is true, then how can you "turn off" 120 Hz?
My understanding of the original reasoning behind 120 Hz is that it's an even number multiple of 30, 60, and 24 which meant that no matter what the content the TV didn't have to interpolate any fields or frames.
The Third Ball
It is a matter of personal preference if you like it or not.
I have my PS3 hooked up at 1080P, and when I play games, I set my TV (Sony KDL-52W4100) to "Game Mode" which disables all extra processing.
When I watch a Blu-Ray movie, I turn "Game Mode" off which enables "Motion Flow" and "Cinema Flow" which enables the 120Hz processing. This gives the picture an almost 3D feel to it. Like I said, it is a matter of personal preference if you like it or not.
From what I understand, it is not just a refresh rate, but the processing the TV does to generate the extra frames to display.
The Third Ball
Damn, I don't think I have a room big enough for that. Guess I have to buy a new house too...
Matt
The Third Ball
It doesn't do away with interpolation as much as it makes 3:2 pull down unnecessary. The standard 60Hz panels need 3:2 pulldown to display programming that was shot at 24Hz. 3:2 pull down meant that each frame of the 24Hz program was displayed on the 60Hz panel twice in succession with each third frame displayed three times. (eg. F1, F1, F2, F2, F3, F3, F3, F4, F4 etc.) The result was that the picture still seemed a little jittery. A 120Hz panel will display a 24Hz program normally just by displaying each frame for 5 refreshes. Motionflow (Sony's name) tries to go one better by interpolating frames within those 5 refreshes, thereby making the picture even smoother but also introducing "frames" that were not in the original program. A movie shot in 24Hz will look too much like videotape if the motionflow feature is not turned off because the interpolation will approximate the 60Hz nature of videotaped material.
You're kinda there...except replace Hz with FPS...movies aren't shot in HZ
That is something for Televisions and Monitors...and really has nothing to do with actual production.
My understanding is that with normal 60i video 3:2 pulldown will result in some displayed frames that are a mixture of the even and odd fields from adjacent frames. It's in this sense that I was referring to a TV "interpolating" the content of a frame. With 120 Hz refresh rate, the TV doesn't need to "make things up" in this manner. It simply takes the complete contents of a frame, as it exists in the source material, and displays it multiple times in succession.
Matt
Are you using a PS3 for Blue Ray? I know the PS3 will display it at 60hz or 24fps. Also, I believe your Samsung has something called "film mode" for 24fps, but I have never used it.
Received 2,329 Likes
@ the Will Smith comment
So for movies what would be the ideal refresh rate?
And for games?
And for games?
For movies I think the ideal refresh rate is 24fps. That is the rate at which the movie is displayed at the theater. If you are trying to get your home theater system to replicate as much as possible the movie going experience then 24fps is the number you want. For games, I think you would want as high a refresh rate as possible that can be supported by your hardware.
