Window Question
Old May 29, 2007 | 07:02 PM
Sly Raskal's Avatar
Window Question
The window in our bathroom is clear. Without needing to replace the entire window, is there anything we can do to give it that glazed or frosted look?
Old May 29, 2007 | 07:16 PM
moeronn's Avatar
is learning to moonwalk i
Cover it with about 100 "etched glass" Acurazine stickers
Actually, I think there are some "etched glass" spray paints. Just make sure you test it out on something first.
http://www.suite101.com/lesson.cfm/17418/943/3
Krylon makes a spray paint that is good for faking an etched or frosted glass look in a hurry. They also carry colored glass spray. To cover a fairly large surface in a hurry this may be your best option, as spray goes on more smoothly than does brushing. And brush marks can be very obvious in glass paint if you aren't careful.
A search just turned up etching gream:
http://familycrafts.about.com/cs/gla.../071601a_2.htm
Old May 29, 2007 | 07:21 PM
Sly Raskal's Avatar
Thanks for the info man! I had heard about the paint method. Didn't know if it I should go that route or not. But after reading that comment, it makes sense to try the paint method.
I'll leave the stickers for the members that keep asking for them.
Old May 29, 2007 | 11:50 PM
jcl_cls01's Avatar
I have the need for speed
Checkout homedepot.com and search for window film. Here's what I found:
http://www.homedepot.com/webapp/wcs/...ctId=100076189
Old May 30, 2007 | 08:40 AM
65 Fury Convert's Avatar
That's what I used on my window as well. Just peel and stick.
Old May 30, 2007 | 08:42 AM
fdl's Avatar
fdl
Ya, your cheapest, quickest option is the stickers they sell at home depot.
Old May 30, 2007 | 10:48 AM
GINge!'s Avatar
Health's Angels
there's a trick to putting on the sticky film to avoid air bubbles. If you can, remove the window from the casing and lay it down on a table to work on.
cut your sheet slightly oversize
peel back the film from the backer sheet so that 1/2" shows
stick the exposed part to the top of the window, and then slowly slowly pull the backer sheet out from under the film, smoothing it from the centre outwards.
Use a new #11 exacto blade to trim.
Or, get the spray on stuff!
Old May 30, 2007 | 02:31 PM
Moog-Type-S's Avatar
The sizzle in the Steak
Go with the frosted window film that you can purchase at Lowes or Home Depot.
Very easy to install. I have done it on a couple of windows, and it was easy, & turned out great with no bubbles or creases.
EDIT: The film is not sticky. It uses a spray on wet application that is very simple...if you screw up, it's easy to re-apply until you get it right...so long as you keep spraying it and keep it wet.
Old May 30, 2007 | 02:38 PM
cM3go's Avatar
I bought my sticker film from IKEA, it was like $5, I used it on my master bath window.
Old May 30, 2007 | 05:40 PM
moeronn's Avatar
I didn't know there was a film. That sounds like an easier way to go.
BoricuaTL
Apr 8, 2016 01:08 PM
06TLMatt
Oct 2, 2015 08:14 PM
wcimo
Sep 21, 2015 10:55 AM
datadr
Sep 12, 2015 09:12 PM
ahsm
Sep 9, 2015 08:35 AM
