Stupid moving question......fitting a couch through a standard door....
Professional Lurker
Ok this might be common sense, but I have a standard door (36 inches across), but at its tightest point its about 33 inches across (the door frame comes in. Most couches I'm coming across are 34x34 height and depth.....should it not be a problem if the couch is tilted on its side?
There's not much room to angle coming in either, as the walls in my apartment are about 9 inches away from the door on both sides......
Like I said, probably a common sense question, but figured I'd get my bases covered before I fall in love with a couch and have to enjoy it in my complex's hallway. So if you have any similar experience it would be greatly appreciated.
Go Giants
Sectionals FTW
05/5AT/Navi/ABP/Quartz
Measure (at least) twice, buy once. You are wise to think about it in advance. Sounds like nothing oversize for you. Depending on where your apartment is located, removing a window may be a posibility. Don't forget to consider elevator, stairs and hallways too. It's a real PITA to have something delivered that you can't get in the house. Been there, done that. I have had issues with refrigerators, desk, couches and a few other things over the years. Now I have sliding glass patio doors and can get about everything in.
Measure measure and measure. That being said, most couches will fit through a standard-sized doorframe. The legs usually will also detach and free up a couple of inches as well.
And as the ex-fatso said above, sectionals are great if possible.
tigerstyle
Yea, i'm pretty sure when they design apartments/condos they take into account the fact that your gonna have to get furniture into them. Though it might seem tight with angles and turns, you should be able to make it work.
Received 2,787 Likes
hahaha i found out my old roommate at my old apt couldnt figure out how to get the couch out of our apt, so he just hacked it up and threw it away
Go Giants
Setup a video cam and we will all post our thoughts on which way you should tilt it....After 5 minutes we will then all scratch our heads, sit on our couch, have a drink and try again.....It should work the 2nd time.
SidhuSaaB
05-30-2020 12:40 AM
ITSJESTER
17
12-06-2018 02:29 AM
09-25-2015 06:14 PM
