Snowblower backfiring....
Old Dec 12, 2005 | 08:21 AM
Crazy Bimmer's Avatar
So i started the snowblower and it starts to backfire like a motha. The oil level is fine so i asked my old man what he did while i was on vacation. He told him he put the year old gas in there.
Whats my best bet here, run the blower till the gas is out or just drain it all out?
Old Dec 12, 2005 | 08:52 AM
dallison's Avatar
registered pw
check the plug too,
drain and refill with new gas to see if the gas is the problem.
also check to see if there is an air filter, typically on yard machines, noone really checks these. it may be blocked
Old Dec 12, 2005 | 11:35 AM
65 Fury Convert's Avatar
2 or 4 stroke engine?
Old Dec 12, 2005 | 11:37 AM
I have a 4 stroke and it would not run unless the choke was on. I richend up the carb with the one screw that is on there and go it to run with the choke off until it was backfiring through the exhaust, then I leaned out the carb until it stopped backfiring but ran with the choke off.
Old Dec 12, 2005 | 01:04 PM
Its a 4 stroke Honda.
I runs with the choke on but backfires like a motha when its off.
Should i try changing the gas first before toying with the carb?
Old Dec 12, 2005 | 01:21 PM
Yea change the gas first. You can let it run itself out of gas, that will get all the old gas out of the carb or a combo of drain and run it out of gas. Then put the fresh stuff in and see how it runs.
Old Dec 12, 2005 | 01:37 PM
So it wont damage anything if i let it run with the backfiring?
Also should i let it run on choke or off?
Old Dec 12, 2005 | 03:09 PM
When running it out of gas it won't hurt anything when it runs backfiring and let it run with the choke off.
Old Dec 12, 2005 | 03:50 PM
oneilc's Avatar
Kenpachi Teichou
what about dry gas?
Old Dec 12, 2005 | 04:08 PM
No idea what dry gas is.
Old Dec 12, 2005 | 04:11 PM
Originally Posted by dallison
check the plug too,
Yea a new plug is always a good idea - matter of fact I'll replace mine too. I don't think snow blowers have airfilters - they can freeze up. It probably depends on the model though. My 8hp doesn't.
Old Dec 12, 2005 | 06:21 PM
oneilc's Avatar
Kenpachi Teichou
http://www.glossary.oilfield.slb.com...Term=dry%20gas
Dry gas is used to remove condensation from gasoline. It is commonly used during the winter months to prevent water from getting into the engine.
Old Dec 13, 2005 | 02:24 PM
dallison's Avatar
registered pw
update ?
Old Dec 14, 2005 | 10:12 AM
I havent done anything yet. Guess i should since we suppose to get 3-5 inches.
Old Dec 14, 2005 | 10:51 AM
dallison's Avatar
registered pw
doopstr
Home & Garden
Apr 26, 2011 09:11 PM
The Dougler
Home & Garden
Feb 27, 2010 05:06 PM
Scrib
Home & Garden
Jan 12, 2010 04:24 PM
2001AudiS4
Home & Garden
29
Mar 3, 2009 09:36 PM
