Question.. What should I do?
Old Sep 12, 2010 | 03:26 PM
hornyleprechaun's Avatar
Bent = #1
July 28th I had a new A/C unit put in (the entire unit). First couple of weeks it was functioning good, then the week/weekend of August 30th it wasn't cooling properly. They came out, found a freon leak, fixed it and refilled the freon.
Started cooling properly again.. Since Friday it has stopped cooling properly again.. I called yesterday, but they can't get someone out till tomorrow, so the house is 82-83 right now.
I was thinking of calling them and complaining because it shouldn't take 2 service calls to get a brand new unit to function properly. I was going to ask for a $100 credit. Does that sound good? Too much? Too little? Should I not call? Thanks for the help.
Old Sep 12, 2010 | 03:54 PM
doopstr's Avatar
If it's losing coolant that fast then it's a pretty big leak. Could be a sign of a poor installation or a defective part. My unit has a coolant leak but it takes 2 years for it to get to the point that it needs recharging. I can't find anyone willing to take the time to find the leak. They all say "replace it and give me $5k".
If it's not fixed this time get a supervisor involved. How is their BBB rating?
Old Sep 12, 2010 | 04:52 PM
gypsygirl's Avatar
Great. Now he's loose.
Do A/C units have lemon laws?
Squeaky wheels get oiled. Call again and again until you get satisfaction. I would guess you paid much more than 100.00 for the unit...yes? Well, get your money's worth.
Old Sep 12, 2010 | 06:45 PM
Street Spirit's Avatar
I would ask for a whole new unit (warranty). Shouldn't have a single issue with it unless there is a manufacturer's defect.
Old Sep 12, 2010 | 07:50 PM
Bent = #1
Yeah they're coming out tomorrow to see what's wrong with it. Pretty positive it's another freon issue because it will put out air, but it's not cold air, more like lukewarm air. I'll wait and see what is wrong with it, as I don't pay anything since it's under warranty. It's just a hassle to not have cold air when I should.
The techs that come out are extremely friendly and helpful, and I don't have a problem with the company. It's just frustrating to sit in a house that can't get below 82 degrees during the day. When the A/C is running properly it feels amazing at 78 degrees.
Old Sep 12, 2010 | 08:01 PM
NSXNEXT's Avatar
I say give them one more chance. As mentioned, no way it should be leaking that much freon.
Find out how much freon had to be added.
Old Sep 13, 2010 | 08:53 AM
Xander Crews's Avatar
x2. This could just as likely be a defective part as it could defective workmanship on the part of the installer. If the next repair doesn't work, I'd press for a new unit.
Old Sep 13, 2010 | 06:06 PM
Bent = #1
So the guy came out and it is definitely a freon leak. He said he couldn't find the leak, but they will have to come back and do a special test to find it. He said it is either the pipe running down the wall from the attic or the coil. He filled up the freon though so the machine is cooling temporarily.. it's nice to have cold air again.
Old Sep 14, 2010 | 11:47 AM
dallison's Avatar
registered pw
after a few attempts w/o success, i would demand a new unit.
Old Sep 14, 2010 | 11:54 AM
NSXNEXT's Avatar
It's a freon leak. It has to be something within the unit. There shouldn't be any pipes "running down the wall from the attic" carrying freon.
Old Sep 14, 2010 | 12:27 PM
doopstr's Avatar
Gotta love these guys. It's nice to see the techs are the same in GA as they are in NJ. First dude told you he fixed the leak, second guy knew he was coming out to find a leak but didn't have the equipment needed.
Old Sep 14, 2010 | 01:50 PM
CocheseUGA's Avatar
What's the company name? My BIL works for one.
Old Sep 14, 2010 | 02:02 PM
Bent = #1
? Maybe I phrased it wrong, but he said the pipes running from the outside unit to the unit in the attic could have a leak since the newer unit has higher pressure than the older unit. He said it was either that pipe or the coil leaking, but couldn't test it unless the lines were emptied.
Casteel Heating & Cooling
Old Sep 15, 2010 | 08:28 AM
Bent = #1
Prelim report as my wife is home while I'm at work. The guy found a crack in the pipe, but luckily it was outside, but not behind the wall. He just has to replace a small portion and weld it back on. Hopefully that's the only crack
Old Sep 15, 2010 | 08:38 AM
gatrhumpy's Avatar
Chapter Leader
(Northeast Florida)
Hopefully that fixes the problem.
Old Sep 15, 2010 | 09:42 AM
Bent = #1
It is all fixed and it was FREE! Covered under warranty!
Old Sep 15, 2010 | 09:46 AM
doopstr's Avatar
I like the commercial on their website.
Old Sep 15, 2010 | 10:03 AM
dallison's Avatar
registered pw
nice
kosstick
Dating & Relationships
70
Aug 28, 2008 11:48 AM
jose416
Mar 29, 2008 02:21 PM
Shoshinsha_KiDs_CL
1G CL Problems & Fixes
26
Nov 17, 2007 10:48 AM
Code_25
Jul 19, 2007 07:34 PM
nippon_wa
Dec 13, 2004 10:37 AM
