Is putting together a BBQ hard/time consuming?
Old Sep 18, 2005 | 06:22 PM
Doom878's Avatar
I got a Char Broil gas grill. Just your regular BBQ with a burner on the side. Is it super complicated where I should set aside a Saturday, or can I tackle it after work?
Old Sep 18, 2005 | 06:24 PM
JWhite1301's Avatar
In need of an AV.........
Depends on the make and model. I have put 3 together within minimal time.
Usually a screwdriver and a wrench.
Old Sep 18, 2005 | 06:40 PM
Doom878's Avatar
How much time did you need. I get home at like 7ish so light is limited.
Old Sep 19, 2005 | 06:47 AM
Reddly9007's Avatar
Stay or leave
My girlfriends parents just bought us a Charbroil grill this weekend for our new home and I threw that thing together in like 20 minutes. Its really simple, not tools necessary for mine, plus the burner and dials already came installed. You can easily do it after work.
Old Sep 19, 2005 | 08:03 AM
Scrib's Avatar
Administrator Alumnus
it's a piece of cake...
Old Sep 19, 2005 | 09:58 AM
Rock2534's Avatar
should only take an hour at most, the longest part is ripping everything out of the box and sorting it out. It helps if you have someone to help and hold things while you tighten things up.
Old Sep 19, 2005 | 10:21 AM
doopstr's Avatar
If it's big enough you are going to need a helper to lift it.
Old Sep 19, 2005 | 10:26 AM
Doom878's Avatar
thanks guys. I'll tackle it after hurricane #12451251252 passes through here.
Old Sep 26, 2005 | 12:49 PM
Doom878's Avatar
So during the Dolphin game we put it together. I bought a tank and everything but quick question. The booklet recommends a leak test. I bought my tank from Home Depot and it's full. Should I go ahead and test it or is it a waste of time.
Old Sep 26, 2005 | 01:54 PM
NSXNEXT's Avatar
Leak test for the tank or the entire system?
Old Sep 26, 2005 | 06:05 PM
moeronn's Avatar
is learning to moonwalk i
You have two options for a leak test:
A. Turn on the gas, but leave the burners off and listen for leaks. If you don't hear anything after the initial filling of the line, you should be good to go.
B. Turn on the gas, turn on the burners and hit the ignitor switch. If you don't lose your eye brows, lashes and eye sight, you are good to go
Just double check your connections and try option A to be safe. I don't think any of the home improvement stores ever leak test their pre-assembled units. Did they recommend brushing on a water/soap solution to test for bubbles? That would be a good test, but seems like over kill.
Old Sep 27, 2005 | 12:00 AM
Doom878's Avatar
Yeah the booklet said to brush the tank.
SidhuSaaB
May 30, 2020 12:40 AM
spoiler900
Oct 10, 2015 06:48 PM
2ManyHobbies
Sep 24, 2015 09:23 PM
Rcelestino93
Sep 23, 2015 10:01 PM
