Popcorn ceilings and asbestos?
Our house has three rooms with the popcorn ceilings in them. I did some searching and found out that these contain asbestos? The problem is moving everything out of these rooms will be a major PITA. But the matriarch wants it gone.... the thing that bothers her the most is the looks. Anyone had this done before?
![](http://maztulis.files.wordpress.com/2009/01/can-of-worms.jpg)
Needs more Lemon Pledge
Can you fill it in with spackle and smooth it out?
Damn people remodeling our house told us it'd take about a week and we just have to move everything out of the house. I'll try and look up that spackle fill-in and the plastic sheet removal method. Funny cause I was wondering why they don't just put a big sheet over everything and just take it off that way....
I was just worried about the asbestos factor. I read up that some asbestos sources are best left undisturbed lest you send the fibers flying everywhere for you to inhale. I actually didn't know about spackle, or the knock down finish, or most things about remodeling or painting... our entire house has a knock down finish though, including the ceilings that were redone, so it should match nicely
thanks
thanks
![Cheers](https://acurazine.com/forums/images/smilies/cheers.gif)
OK, full disclosure, I was kidding about the spackle... Who knows, though. It might work!
does the popcorn ceiling have any sparkles in it? Is it large chunks of "popcorn" or finer bits like the size of crumbs?
Wait a minute? How old is the house?
Does the popcorn ceiling, in fact taste like popcorn?
Nom nom nom
![Popcorn](https://acurazine.com/forums/images/smilies/popcorn.gif)
No sparkles. Popcorn is bread crumb size, albeit it looks painted white ones that are affixed to the ceiling. House was made in the 60's.
and no, it doesn't taste like popcorn. In fact, I actually feel really sick now
![Puke](https://acurazine.com/forums/images/smilies/puke.gif)
![Bite Lip](https://acurazine.com/forums/images/smilies/bitelip.gif)
SHAWD 04TL is in
PIECE of cake. Nothing to lose sleep over. you can do it yourself with a paint sprayer that you can rent from HOME DEPOT.
step 1: move as much furniture as you can out of the room. Whatever big furniture you cant move, just slide to the center.
step 2: lay painters plastic over all flat floor areas FIRST! Tape securely to carpet or baseboards. Then move on to covering all furniture with the plastic. Then cover walls with more plastic.
step 3: repeat step 2... add a second layer of covering over the first. You'll see why in a second.
step 4: load the paint sprayer with "WATER" (not paint) & spray lightly and evenly over the popcorn. The popcorn will absorb the water & practically flake off with a large "wide" putty knife. (only runs a few $ at home depot")![](http://ecx.images-amazon.com/images/I/316rjR83pgL._SL500_AA300_.jpg)
Some parts of the popcorn may be tougher to remove & might require more water spray. ie the corners & edges sometimes seem harder due to paint being overlapped from the walls & ceilings when they were painted previously.
step 5: after you remove the popcorn wrap in the first layer of plastic... and waaalaaahh, you have a clean layer of plastic ready for whatever texture you choose to lay for your new cieling finish...
not: A cheap-y air mask is recommended, but most of the fibers are subdued due to the water making them heavy & they fall over the plastic protective layer you lay down.
![](http://ecx.images-amazon.com/images/I/31ar-9OU-aL._SL500_AA300_.jpg)
Ive done this plenty of times when I worked for the FAMILY COMPANY, so if you have any other ?'s... PM me.
ENJOY.
ENJOY.
The Dumb One
ahhh something i can finally chime in on..
1. popcorn ceilings may or may not have any harmful ingredients in them. it solely depends on when the ceiling was sprayed. (in your case it doesnt matter b/c its coming down anyway)
2. popcorn texture or "acoustic" texture is still sold widely today and even put up in new housing/businesses. its cheaper to spray then your standard orange peel or level 5 finish. (which is why its still used alot in hotels)
3. the instructions listed above are pretty much spot on for removing it.
my suggestion to add would be use a much wider knife than the one above for scraping... (puddy knives are fine but using a 10-14" drywall mud knife covers more ground and are generally stiffer) they are still $10 and under.
and about the knockdown finish... its nothing more then a standard orange peel finish that somebody came back over gently with a wide mud knife and flattened the surface. very easy to do for somebody with little-no experience.
i manage a drywall products company... i can tell you what you need to know about pretty much anything wall/ceiling related.
dont hesitate to ask for more info... subscribed..
Asbestos was mainly used for insulation, it was a little $$ to use. So I think that it wouldn't have been used to popcorn ceilings in most houses, it would have add extra cost to the price of the build.
SHAWD 04TL is in
Chapter Leader
(Northeast Florida)
(Northeast Florida)
As Jupiter said, asbestos was mainly used for insulation, but I would not take chances. There have been instances where asbestos was found in floor tiles from the 60's and 70's. Do you really want to jeopardize your family's health to remove a ceiling? I would contact a company, or, at the very least, get a full-on bunny suit with mask, goggles, and respirator and seal everything up to remove it. Remember to have someone help you and to blow off all fibers when you leave the sealed room.
![RIP](https://acurazine.com/forums/images/smilies/smitty.gif)
Hey I'm having an asbestos party. Come on over. We have bacon, waffles, and you get to dress like an astronaut.
I'm listening... Go on...
It's more likely in the drywall joint compound (drywall mud) than the spray-applied accoustical ceiling. In the 60's and 70's (and even 80s) it was very common. Surprisingly it can still be found in products today (most of which are manufactured in Canada, Mexico, or China).
Late update, well, not really but we haven't done shit. Me and my sister are resistant to moving every single god damn thing out of our rooms and back.
My mom just likes to spend a shitload of money without researching or truly understanding what she's spending money on. See the other thread that I'm going to make in a minute or so. I don't know if the popcorn ceilings had asbestos in them, and I highly doubt the contractor who removed the popcorn ceilings in the other rooms when we first moved in tested for it either. For some god forsaken reason she only removed the popcorn in all but two rooms.
sorry, ranting on here...
In San Jose, California. What's the easiest way?
Take a squirt bottle of some sort and wet an area about 2" x 2" (preferably a corner so you don't notice it much). Scrape the wetted ceiling finish into a ziploc bag.
Send it to this laboratory:
http://www.emsl.com/index.cfm?nav=La...aboratoryID=21
Call them ahead of time to see if there is anything special you need to do.
Thanks mrsteve. I'll give it a try... I know exactly which spot to try too. My room, since frankly I don't give a damn.
Believe me, if I could have I would have moved out 2 years ago. I can't find a full time job that supports that though.
rockyboy
12-06-2022 02:29 PM
