New Garage Floor
Old 01-23-2008, 04:26 PM
Chapter Leader
(Northeast Florida)
gatrhumpy's Avatar
Received 1,652 Likes on 1,117 Posts
New Garage Floor
Before:
After:
Old 01-23-2008, 04:29 PM
Newbie for Life
Tripp11's Avatar
Process? Material used?
Mine has a "do it yourself" epoxy floor, but the previous homeowner did not adequately prep the concrete prior to applying the epoxy - thus, another summer task on my list.
Old 01-23-2008, 04:36 PM
asianspec's Avatar
Received 1,097 Likes on 831 Posts
very nice.
Old 01-23-2008, 04:37 PM
doopstr's Avatar
Received 2,150 Likes on 1,180 Posts
In the before pics, is that floor properly prepared? Mine looks about like that and I'm afraid to put the epoxy on it because I've read that it needs to be perfect.
BTW, looks great.
Old 01-23-2008, 04:48 PM
Chapter Leader
(Northeast Florida)
gatrhumpy's Avatar
Swept the floor.
Used a blower for step 2.
Rinsed the floor with a hose.
Let dry. Rolled on Behr clear epoxy primer. Used .80 gallons.
Waited overnight.
Rolled on Behr epoxy paint with 3/8 inch nap roller.
Waited 24 hours.
Rolled on second and final epoxy coat.
Waited about 60 hours to park the cars in the garage.
Old 01-23-2008, 04:50 PM
Chapter Leader
(Northeast Florida)
gatrhumpy's Avatar
BTW, looks great.
I just prepped the floor like it said in the directions. The primer really helps the epoxy stick to the floor. I wish my floor was smoother and more uniform, but you can't have everything. This weekend I plan on adding another double-wide cabinet next to the other two in the pics.
Old 01-23-2008, 05:11 PM
Unofficial Goat
The Dougler's Avatar
Nice work, Honda Lawn mower FTW!
Old 01-23-2008, 06:00 PM
Chapter Leader
(Northeast Florida)
gatrhumpy's Avatar
Thanks. We're a Honda family. My wife has an '03 Civic!
Old 01-23-2008, 06:04 PM
is learning to moonwalk i
moeronn's Avatar
Looks great!
Old 01-23-2008, 06:10 PM
Unofficial Goat
haha same here, My old man works for them, so we have quite the laundry list of products.
Bro has 07 TL-S NBP 6MT
I have 05 TL NBP 6MT W/Navi
Dad has 05 Accord NBP EXL 5MT
his G/F has 00 Civic Silver DX 5 MT
Also keep a 95 Accord EX-R green Auto, in the garage as a random backup
String trimmer
Mower
Snowblower
Water Pump.
And I think there's a small generator kicking around somewhere.
And those are just the current products lol. Btw approx what did the materials run you?
Old 01-23-2008, 06:56 PM
Administrator Alumnus
Scrib's Avatar
Looks nice. I'm assuming the stuff you pulled down won't be impacted by hot tires?
Old 01-23-2008, 06:57 PM
Chapter Leader
(Northeast Florida)
gatrhumpy's Avatar
String trimmer
Mower
Snowblower
Water Pump.
Materials ran me about $90 at Home Depot.
1 gallon primer
2 gallons epoxy
three paint rollers
Old 01-23-2008, 06:58 PM
Chapter Leader
(Northeast Florida)
gatrhumpy's Avatar
I hope not!
I am parking the cars in the garage a little sooner than the label says, but I haven't driven my car at all in about three days, so no hot tires on my car!
Old 01-23-2008, 07:03 PM
crazymjb's Avatar
If I ever own a house, and the required 3 car garage, one space with a high capacity lift, I'd probably put this stuff down: http://www.garagefloor.com/garage-fl...opsandpits.htm
Or some variation of it. Anybody have that?
Your garage floor looks nice BTW.
Mike
Old 01-23-2008, 07:07 PM
Scrib's Avatar
I hope not!
It's not even that... Regular driving heats up the tires. So over time and if the paint hasn't properly bonded to the concrete, the tires will pull the paint up. You'll notice it over time.
Living the Dream
cmschmie's Avatar
Looks great, I wanna do the same thing to my 1-car
P.S.
How much for the silver stars?
Old 01-23-2008, 07:40 PM
I feel the need...
Fibonacci's Avatar
Nice work gatr!
Old 01-24-2008, 08:50 AM
Chapter Leader
(Northeast Florida)
gatrhumpy's Avatar
Originally Posted by Fibonacci
Nice work gatr!
Thanks. I really like how my garage is turning out. Speakers in the ceiling, cabinets, new floor. I like it!
Old 01-24-2008, 09:00 AM
The Creator
soopa's Avatar
Mike
If you own a house worthy of a 3-car garage, you'll want a 4-car... trust me.
Especially if you want a lift.
At least 2-slots get filled up by cars (truck gets parked in the driveway), then the other spot is needed for storage/workshop/light-vehicle usage (tractor, atv, motorcycle, whatever).
A 3-car garage is just too small. Mine is filled to the brim.
Old 01-24-2008, 09:01 AM
The Creator
soopa's Avatar
Garage looks great gatr. I am going to paint mine in the spring... can't decide between tan or gray though.
Props on not using the "speckles". They look awful.
Old 01-24-2008, 09:26 AM
NSXNEXT's Avatar
Received 1,080 Likes on 661 Posts
Surprised you didn't have to acid etch the floor. Hopefully it doesn't pull from hot tires.
Old 01-24-2008, 10:45 AM
Moderator Alumnus
SiGGy's Avatar
I would have. Or at a bare minimum used a 3000+psi pressure washer and hit it with some cement cleaner. Oil/grime stains need to be taken out... no primer will save you there.
Old 01-24-2008, 10:48 AM
NSXNEXT's Avatar
Is it a brand new house? Did you do the moisture test? You tape a piece of saran wrap down on the floor with duct tape and let it sit for a day. If there is moisture under the saran, the floor won't bond properly.
Old 01-24-2008, 11:27 AM
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
Ill be doing mine in the spring with the U-Coat it system. Ive had years of working on cars and oil and grease on my floor from all my projects so i will diffenately be acid washing the floor.
Looks good though gatr
Old 01-25-2008, 03:18 PM
Chapter Leader
(Northeast Florida)
gatrhumpy's Avatar
Thanks! That means a lot coming from you!
Honestly, the only reason why I didn't use sparkles is because the paint didn't come with them. Just plain grey for me.
I wish I would have used a tan color to semi-match the walls, but I kind of like the contrast now.
Old 01-25-2008, 03:19 PM
Chapter Leader
(Northeast Florida)
gatrhumpy's Avatar
Behr said I didn't need to. Just sweep, blow-dry, wet, squeegee, dry, prime and paint!
Old 01-25-2008, 03:20 PM
Chapter Leader
(Northeast Florida)
gatrhumpy's Avatar
The house was built in 2003.
Old 06-15-2008, 02:01 PM
Pushing_Tin's Avatar
To the OP, how is your floor holding up? I have been reading a lot about epoxy floors and so far many people are having problems with the floor peeling or lifting.
I have narrowed my choices down to these:
http://www.armorcladepoxy.com/
http://epoxy-coat.com/
Old 06-18-2008, 07:16 AM
Chapter Leader
(Northeast Florida)
gatrhumpy's Avatar
I don't know if it's the paint or what, but because of the hot tires here in Florida, the paint started to come up where the tires are about four weeks ago. Wife is out of town for the next four days, so I might paint the floor where the hot tires used to be while she is gone.
I would avoid Behr garage floor paint.
Old 06-18-2008, 01:04 PM
That's pretty much what I've heard from everybody that has used their product. I have a brand new house with unsealed concrete so hopefully I won't have any problems.
Old 06-18-2008, 01:11 PM
Chapter Leader
(Northeast Florida)
gatrhumpy's Avatar
Hopefully you won't, but wait the required week.
Old 06-18-2008, 01:53 PM
Rock2534's Avatar
I used that epoxy stuff 3 yrs ago on my garage. For the most part its held up well, but there are a few spots where it peeled. I did my basement floor with a regular concrete paint and that is flawless. I will be doing my garage with that stuff soon, and for 20 bucks a can its cheap too.
Old 06-18-2008, 02:04 PM
Which epoxy? They all vary widely as far as water content etc. Did you put a top coat on it?
Old 06-19-2008, 12:08 AM
csmeance's Avatar
Received 2,004 Likes on 1,424 Posts
I used the Behr stuff on my concrete floor, had it acid etched and all, and it is starting to come up where the tires are, and the flakes that they have love to come off with a simple sweep... or even leaf-blower...
Old 06-19-2008, 01:10 AM
I ordered the kit from armorclad today. It was $700 shipped, enough for 1000 sq ft. It will be a month or so until I can put it on, but I will post pics and experiences at that time.
Old 06-04-2010, 08:13 PM
Sly Raskal's Avatar
Any updates on the garage floor coating? How's it holding up? I don't know if I want to get my garage floors painted or coated with an epoxy. Also, since the concrete is new, I don't yet know if it's fully cured and if they layed down a vapor barrier which can pose a problem with the concrete and epoxy. So just thought I'd look into every option.
Old 06-05-2010, 02:14 AM
My floor has had a few problems with lifting and peeling issues. The floor was in a brand new house with unsealed concrete. I think one issue was that there was no vapor barrier placed under the concrete so water under the concrete is trying to make its way through to the surface and that is causing the lifting. There are a few places under the tires that have lifted too. I was given some touch up epoxy for free under warranty so I scraped the loose stuff up, sanded it and reapplied the epoxy. Within 6-9 months it lifted again in the same area.
I can post pics if you like.
Old 06-05-2010, 07:08 AM
NSXNEXT's Avatar
Yeah typically you need to wait a while for new concrete to fully cure before finishing the surface.
I did mine in my old place. Decided to prep the floor with muriatic acid to really give it teeth for the coating to stick to. Nasty stuff but it really roughs up the concrete.
Old 06-05-2010, 11:39 AM
KaMLuNg's Avatar
Received 1,090 Likes on 767 Posts
where do you get muriatic acid???
Old 06-05-2010, 11:58 AM
NSXNEXT's Avatar
Home Depot carries it. Some say to dilute it but I used it full strength.
Wear a good respirator, long pants and shirt, face shield
Have a box fan sucking the fumes out of the garage
You need a short hair stiff bristle brush to scrub the acid into the concrete
Hose to wash the acid out of the garage.
I've read where people throw down baking soda to neutralize the acid but it seems like a mess.
Be careful getting it on any metal surfaces, it's nasty stuff
You'll know you did it right it the concrete has a rough feel to it when you're done.
Quick Reply: New Garage Floor
