need a good edger for the springtime
Old Dec 20, 2006 | 02:34 PM
dallison's Avatar
registered pw
i know spring is a few months away and winter is a day or so away, but.....
we have about 150 ft of sidewalk to edge.
the grass is currently overgrown over the cement by 2-4 inches.
i was on one of the lanscapers forums and found a little info that would help me.
but i need a less professional unit that will do a sweet job.
i guess i am expecting to spend about $200 or so. but that is a ballpark figure.
lowe's has a husquvarna for $200, is that a good starting point or are there better choices?
Old Dec 20, 2006 | 03:12 PM
pmptx's Avatar
Honda+Blue=My garage
The Stihl Combi is awesome. I use it for trimming and change the ends for the edging duties. About 350 all in with both ends
Old Dec 20, 2006 | 03:24 PM
dallison's Avatar
registered pw
now what if i have a trimmer?
i have a craftsman 4 cycle that is not a straight edge.
i wasnt sure if i could get an edger that does not operate as a trimmer
Old Dec 20, 2006 | 04:42 PM
Scrib's Avatar
Administrator Alumnus
Get a gas trimmer.... I have a Toro. Works fine for me.
Old Dec 20, 2006 | 05:52 PM
GreenMonster's Avatar
Rich, does your craftman wacker have the "quick tatch" or "expand it" options like most of the ryobi/toro/homelite/deere ??
On some of these deals, you can just change the head... I've borrowed my step dad's tiller attachment a couple of times to use on my trimmer...
Old Dec 20, 2006 | 07:17 PM
dallison's Avatar
registered pw
you know i'll have to check, it's a 4 cycle and i think i paid like 220 for it 2 years ago, but ill check
Old Dec 20, 2006 | 08:57 PM
$219
https://acurazine.com/forums/home-garden-37/my-weedwacker-purchasing-experience-308614/
Old Dec 21, 2006 | 09:35 AM
dallison's Avatar
registered pw
Originally Posted by GreenMonster
Old Dec 21, 2006 | 10:31 AM
bl^5's Avatar
Got da Internet Goin Nutz
I had the same issues as you did with your first weed eater and I took mine back and got a walk behind push edger. I love it and would rather have it than a weed eater. I actually need a weed eater to cut next to the fence, house, etc. but for right now, I just edge the sidewalk and driveway.
If you already have a weed eater I'd suggest a walk behind gas edger. They are four cycle, and very easy to use. If you have grass next to your curb, and if you can afford it, go with the one with three adjustable wheels so you can edge next to the curb. If you have sidewalk next to your curb, don't worry about it, get the cheaper non adjustable version.
You paid enough and bought your weed eater recently enough, that it should accept attachments. If so you can probably forget my post and just get the attachment. If not definitely look into the walk behind gas edger!
Old Apr 18, 2008 | 07:39 PM
Scrib's Avatar
My Toro is having issues... Any recommendations???
Old Apr 18, 2008 | 08:01 PM
svtmike's Avatar
I have the cheap ($70) black & decker plugin model (marked "2hp" but there's no way it's an honest 2hp) to edge against my concrete walks and driveway. As long as I keep after it regularly, it is more than up to the task.
It's worked for me now for 10 years.
Old Apr 18, 2008 | 09:13 PM
timmahh's Avatar
it's me, Alan Rickman.
I've got a gas powered edger.. does a nice clean job! I think its yard machines or somethin.. works good
Old Apr 19, 2008 | 09:02 AM
doopstr's Avatar
I'm starting my 3rd season with an Echo SRM-210. It's friggen awesome. The only minor negative is it takes the engine about a minute to warm up before it is ready to go.
I got mine at HD.
Old Apr 19, 2008 | 11:09 AM
Scrib's Avatar
The issue is my toro would take the Expand-It attachments. The above doesn't allow for that. And most of the high end units don't.
Old Apr 19, 2008 | 11:16 AM
doopstr's Avatar
What's the problem with the Toro?
Old Apr 19, 2008 | 12:15 PM
Scrib's Avatar
It's somehow leaking gas. I haven't looked at it close enough, but every morning my my way to work I see gas and oil on the garage floor.
To be honest, I haven't looked at it close enough, but it's not worth messing with. Taking it in for repair is going to be $100, I'd figure.
Old Apr 19, 2008 | 01:00 PM
doopstr's Avatar
Something like that may be fun to try to fix yourself. Worst case is you make it worse and you go buy the replacement you were planning on anyway.
Old Apr 19, 2008 | 04:02 PM
timmahh's Avatar
I don't like using the weed whacker as an edger; I like having an actual edger because the results are consistant.. if you get distracted with a weed whacker you might take out part of the lawn.
Old Apr 19, 2008 | 06:53 PM
jupitersolo's Avatar
nnInn
If you don't have a lot to do and just need an edger. Manual edgers are pretty cheap.
http://www.amazon.com/Yard-Butler-St.../dp/B000RYOAQY
http://www.amazon.com/Hound-Dog-Prod.../dp/B00023S14W
Old Apr 19, 2008 | 07:13 PM
Scrib's Avatar
Picked up a Craftsman 4-cycle... It can use attachments, so I don't have to reinvest in an edger and blower. Got a good deal on it too...
Old Apr 20, 2008 | 02:03 AM
The Dougler's Avatar
Unofficial Goat
We have one of these, but the original 2-Stroke Model
With a tall grass blade and saw blade.
We also have this one for edging.
Old Apr 20, 2008 | 07:32 PM
dallison's Avatar
registered pw
we bought one like this except it is from sears.
works well and leaves a nice straight line. the blade does scrape against the sidewalk and wears down the blade. The replacement blades are a few bucks to replace
Old Apr 21, 2008 | 05:43 PM
Moog-Type-S's Avatar
The sizzle in the Steak
I've had a 4-cycle ryobi for about 5 years now...and it's flawless.
giovane
2G RDX DIY & FAQ
Jul 8, 2016 10:46 PM
Pegon95
Sep 15, 2015 01:54 PM
PortlandRL
Sep 14, 2015 12:01 PM
NSolace
Sep 3, 2015 08:02 PM
