Loo issues
Needs more Lemon Pledge
Loo issues
My toilet runs. Almost all the time.
The insides look like:
![](http://korky.com/images/AnatomyTank.jpg)
The rubber hose from the left side to the right side is what is almost always piping water down the tube, and thus into the bowl.
These new-fangled toilet guts have me confused. What do I do?
Need more info.
If the hose is running then the tank should also be trying to fill with water. Is the water in the tank spilling into the same hole that the hose pumps into? If so then you just need to adjust the shutoff level of the fill valve.
These things usually boil down to adjusting something or replacing the fill valve and/or flapper.
I've done this stuff successfully and my plumbing skills are low.
Need more info.
What do I do?
All the repair stuff I see online is for the old ball float style toilets...
The problem is most likely the flapper valve. Replace it and see if it still runs constantly.
Mr Marco (03-16-2013)
I will look for an adjustment screw when I get home. I am guessing that the water level in the tank should not be at the very top of this center tube?
Unofficial Goat
Flapper is OK, the water leaking into the bowl is from the small tube that points into the top center of the ?flush tube? in the middle. When I pinch it off, the flow into the bowl stops.
Thanks Dougler!
I found a video for the exact style I have. Looks like it;s the same procedure as you posted. 1/4 Turn counter clockwise to unlock and adjust height. I will give it a shot tonight.
http://www.youtube.com/watch?v=PF6gKvlxICA
check the flapper first... it should have some silicone on the bottom that seals any leaks into the bowl while it is closed... i suspect you have a leak there which is causing the fill valve to continue to run since the water level doesn't reach the top of where it is set to...
You need to change out the entire flush valve assembly. I had same problem while back, couldn't find leak nor would adjustment do it.
And if you're calling it a loo, more problems than just water.
Could be the flapper is fine and there's some foreign object keeping it from closing completely. Stick your hand down there and feel around.
![](https://acurazine.com/forums/members/svtmike-121620-albums-svtmike-s-gallery-6094-picture-trouble-loo-37928.jpg)
Mike, You suck.
Big time.
Big time.
:zing:
![pofl](https://acurazine.com/forums/images/smilies/pofl.gif)
Endo,
may you slip and fall on a grape at the grocery store and fall face first into the sweaty butt crack of an obese Jenny Craig dropout on her way home from her "Ass Sweats A Lot Anonymous" meeting...
So...that's where you get your rebound chicks from
You sure it wasn't her that caused your toilet leakage problems to begin with
weight watcher reject -->
<---Stogie
I'll be sure to watch out for those pesky once in a lifetime random hazardous grapes...thanks for the heads up
![Bite Lip](https://acurazine.com/forums/images/smilies/bitelip.gif)
![Hurry](https://acurazine.com/forums/images/smilies/hurry.gif)
The sizzle in the Steak
upper deckers usually stop the leaks....try it.
![Ninja](https://acurazine.com/forums/images/smilies/ninja.gif)
![Turd](https://acurazine.com/forums/images/smilies/turd.gif)
Flapper seems to have fixed the issues. Woot.
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
Flapper, no you need a fluffer!
Flapper = 1930's fluffer!
You suck You suck You suck You suck You suck You suck You suck You suck You suck You suck You suck You suck You suck You suck You suck You suck You suck You suck You suck You suck You suck You suck You suck You suck You suck You suck You suck You suck You suck You suck You suck You suck You suck You suck You suck You suck You suck You suck You suck You suck You suck You suck You suck You suck You suck You suck You suck You suck You suck You suck You suck You suck.
Not sure if it was the toilet or the 1/2 reduction in lawn watering time, but I just got my water bill and it is OVER 50% less than the same month last year.
![Woot](https://acurazine.com/forums/images/smilies/woot.gif)
Received 2,785 Likes
the chain that connects the flapper to the darn handle that flushes the toilet keeps coming off, how do i get it to stop falling off?
super glue?
super glue?
Registered but harmless
Received 1,102 Likes
![Blink](https://acurazine.com/forums/images/smilies/blink.gif)
Just bend the little metal hook on the chain so that it doesn't slip off.
If that doesn't work due to corrosion or a cracked rod, go to a hardware store or Home Depot and buy the toilet handle, rod and chain part-- it's only a few dollars, IIRC.
I may have to do that. The way the handle is designed the hook can't be clamped shut, it like just clips into the handle.
With enough wiggling I could come off again.
(that's what she said...
but not to me)
![Mizouse](https://acurazine.com/forums/images/smilies/quagmire.gif)
OK, new issue...
As mentioned above, I have the Korky style filler valve assembly (http://www.homedepot.com/p/t/2021838...2#.UUS3vxzvv2s).
When I flush the toilette, it flushes fine but then as it starts to refill, it starts and stops the process. It finishes, but in a stooping and starting fashion, such as "start", "stop", "start", "stop","start", "stop", etc. about three or four times until the tank is full. Then it STFU and sits there all
style waiting for me to flush...
Any ideas why it would stop and start while refilling the tank?
