Garage door won't open!!! Help!
Old Aug 31, 2004 | 08:06 PM
Eggplant-EX's Avatar
When I pushed the button, I can hear the garage door opener going but the door does not open. What can I try.
I unplugged it and it does the same.
Old Aug 31, 2004 | 08:11 PM
CLpower's Avatar
teh Senior Instigator
any chance you pulled the emergency handle on it? That stops the chain mechanism if I'm not mistaken
Old Aug 31, 2004 | 08:19 PM
GreenMonster's Avatar
If someone pulled the emergency handle it'll diengage the lift rod from the chain (AMHIK). You should be able to get it back on track pretty easily tho'.
Red-CL's Avatar
Doin' da crack shuffle
You can't overide the opener?
I sometimes open my door manually.
Old Aug 31, 2004 | 08:21 PM
mikeymobiles's Avatar
Movin on up...
is it off the track>? anything in the tracks way?
Old Aug 31, 2004 | 08:22 PM
Slimey's Avatar
Where is my super sauce?
or...you should use your the emergency cable and open it to see if the main drive shaft/cable/belt has broke.
My 15+ year old garage door opener died this winter. Turns out it got so cold the roller mechanism slightly froze and then the chain (or belt-I don't remember) broke. Since it was an old unit I went ahead and upgraded the whole system and had a garage dude service the door.
Here's where I learned something important about rolling garage doors:
A garage door needs maintenance.
You should check the roller bushings yearly as they'll wear and age. You should periodically grease the rails.
Old Aug 31, 2004 | 08:25 PM
Inspection and lube is important. I usually have to adjust the tension on the chain every other year on mine (old craftsman).
Old Aug 31, 2004 | 08:26 PM
Slimey's Avatar
I learned the hard way, but I guess 15 (or so) years isn't too bad between overhauls.
Old Aug 31, 2004 | 08:28 PM
mclarenf3387's Avatar
Drive through it. You don't need it anyways.
Thats what my mom does at least once every few years.
Old Aug 31, 2004 | 08:30 PM
Silver™'s Avatar
Moderator Alumnus
That advice applies to most women too
Old Aug 31, 2004 | 09:10 PM
Somehow the emergency cord got pulled by some idiot living in my house (me!!).
Thanks for the help!!
Old Aug 31, 2004 | 09:32 PM
Gotta clean out the cobwebs every once and awhile too
It's hard to resist, ain't it Big red thing swinging around near your head....
Old Aug 31, 2004 | 09:43 PM
Teh Snaps's Avatar
ITS ALL ABOUT THE GLOW
or well u could have thrown the remote on ground that always helps
glad u got it fixed
Old Nov 23, 2005 | 01:35 PM
TSX 'R' US's Avatar
Old fart
Heh...garage door stopped working last night... opened up the casing and found this:
not even a full month from closing on the house
time for a new one...
Old Nov 23, 2005 | 02:00 PM
CLpower's Avatar
<---- called it
Old Nov 23, 2005 | 02:24 PM
Always Dirty's Avatar
It amazes me that we don't get more "my tire is all floppy and squishy and my car is driving really funny" threads on here sometimes, given the threads we do get. Maybe they're all in Car Talk though...
Old Nov 23, 2005 | 03:11 PM
phipark's Avatar
Not Asian
The noobs are frightened to post in here.
Old Nov 23, 2005 | 03:25 PM
ricecake's Avatar
Moved to Home & Garden...Glad you figured it out!
Old Nov 23, 2005 | 07:34 PM
Henry, looks like a plastic gear just got chewed up ??
Maybe look into just replacing the gear ??
I'm cheap, so I like to look for the cheap fixes first, but it's not that much to replace the whole unit I guess...
Old Nov 23, 2005 | 07:42 PM
TSX 'R' US's Avatar
Old fart
I'm going to check it out again when I get back tomorrow...if its an easy fix, I might just use that one on my other garage door...at a later date
Now I've gotta decide if I want a belt or screw opener...
Old Nov 28, 2005 | 09:09 AM
Scribesoft's Avatar
Aaaarrrggghhhh!
Get the screw type. Worth the extra $$. Very quiet and smooth..
Old Nov 28, 2005 | 09:58 AM
TSX 'R' US's Avatar
Old fart
Actually...ended up getting a Craftsman screw drive opener... Too bad they're not the same length as the old chain drive I had
Time to drill more holes in my ceiling
rockyboy
Aug 4, 2024 10:35 AM
Feb 25, 2020 09:57 AM
giovane
2G RDX DIY & FAQ
Jul 8, 2016 10:46 PM
Azonics
Sep 22, 2015 05:28 PM
CadiGTi
Sep 14, 2015 06:37 PM
