Fixing the roof?
Old Nov 4, 2009 | 09:37 AM
hornyleprechaun's Avatar
Bent = #1
Fixing the roof?
Has anyone tried to replace part of their roof? The section right above my garage is probably 20ftX8ft. The bottom left has started to leak, and I haven't got any estimates yet, but I'd have to think that doing it myself would be cheapest, and really not that hard.
I think these are the steps..
1) Remove old shingles
2) Replace any rotted plywood (I know the bottom left will be)
3) Lay down felt paper
4) Install shingles
I plan on renting a nail gun from home depot to make the process easier and faster.
Anyone attempted this before, or should I just get someone else to do it?
Old Nov 4, 2009 | 10:45 AM
dallison's Avatar
registered pw
i think it's pretty easy, i would make sure the flashing is installed correctly, if there is any at all. Esp if you think there may be wood damage.
Is your house about 10 years old? If so, something should be done about the premature wear on the shingles. water is getting in somewhere and causing you some damage.
I think replacing the materials shouldn't be hard at all, but somthing needs to be looked at to prevent this from happening again.
Old Nov 4, 2009 | 11:17 AM
Bent = #1
I know what the problem is.. you can barely see in the picture, but there is a gutter on the left and right side that feeds the water from the top roof onto the roof over the garage.. The house is around 12-13 years old, and over time the water has eroded the "glue" that has held the shingles down.
I do plan on replacing any wood that is damaged, and making sure that there is proper flashing. I also do plan on re-routing those 2 gutters to avoid future damage to the new shingles.
Old Nov 4, 2009 | 12:37 PM
subinf's Avatar
One on the right for me
I tried fixing my parents roof once. It didn't seem to difficult but once I tore off the old wood singles they told me they were just going to hire someone to replace the entire thing because they didn't want wood as the roof anymore. I probably would have messed something up anyway.
Old Nov 4, 2009 | 04:42 PM
svtmike's Avatar
Looks to me like the downspout on the left side is too close to the edge of the roof over the garage front, and the torrent that is supposed to run down the garage roof actually runs over the edge left edge, around the lip, and thanks to the wonders of surface tension underneath to the sheathing. I'd route the two second story downspouts all the way to the ground and re-build the roof. Since you don't have to worry about ice dams, just get a book on it and go at it as long as you're confident that you can get the flashing where the second story wall meets the garage roof right (I can't tell what material your house is sided with).
Old Nov 4, 2009 | 04:51 PM
Dr. Colorado's Avatar
I had this known roof leak issue when I purchased my home. A covered lanai (sunroom) was built into the backyard as an addendum. The original monier tile roof is slanted but the lanai room is flat. Well, a half-ass job was done and water would run down the monier tile and under an epoxy coating contiguous between the lanai roof and over the 2 lower rows of monier tile. This led to leaking of the sunroom during heavy rain. The original owner had tried to fix this twice but what needed to be done was remove the 2 lower rows of monier and run a new waterproof coating UNDER the monier and over the entire lanai roof creating a slight grade so water would not pool.
No way I was gonna touch monier with a 10 foot pole so I contracted it out for under $3000 which includes a 5 year watertight guarantee.
In your case looks like you might need to replace only the lower 2 rows? What material is your shingles made of? I agree with Mike on fixing the gutters, I think the downspouts need to be more distant from the roof.
Old Nov 4, 2009 | 05:40 PM
Bent = #1
That was the plan with those 2 upper gutters.. I was going to re-route them straight to the ground, but I haven't really looked into it yet.
The front of the house is stucco, so the flashing near the house wouldn't be too hard to accomplish. I'm going to price material tomorrow, and I already have 1 friend willing to help, and possibly another, which will speed up the process.
I can't just replace the lower 2 rows since the bottom left plywood is rotted.. I'd probably at best have to replace 6-8 rows, but considering that is > 33% of the roof then I may as well just replace the whole thing with new, matching shingles.
The shingles are 3-tab asphalt.
Old Nov 4, 2009 | 05:51 PM
svtmike's Avatar
So I think if it's done right, there is felt paper on the wall which is over the flashing, which is over the shingles. Then the wire lath and stucco is over the felt paper.
When you pull up the old roof, you're going to re-use the flashing and put the new roofing down underneath it? Or is there no flashing there?
BTW, nail gun = waste of money IMO. Get a helper with a hammer to cut shingles and snap chalk lines, etc. since it's such a small section of roof.
Old Nov 4, 2009 | 06:02 PM
Bent = #1
I honestly don't know.. I haven't looked close enough yet.
You think a nail gun for $20 for the day is waste of money?
Old Nov 4, 2009 | 06:05 PM
svtmike's Avatar
Yeah, you won't spend that much time nailing. You'll spend a lot more time putting down the felt paper and cutting the shingles and going up and down ladders.
Edit -- I fixed a small section of the roof on my brother's house a few weeks ago. His siding is cedar shakes instead of stucco. The vast majority of the time was spent getting the flashing and ice dam sheeting right. Actually laying the shingles was a snap; when I was done I had no regrets that we didn't have a roof nailer.
Old Nov 4, 2009 | 06:32 PM
Bent = #1
Thanks for the help. I'll give an update after I price the materials tomorrow.
Old Nov 5, 2009 | 12:12 PM
Bent = #1
Well I talked to a roof guy this morning and he said he would do it for $450.. While I would love to do the roof myself, I think $450 is a great price to pay to not have to do any work
Old Nov 5, 2009 | 01:13 PM
Take it and run! Just make sure he warranties it for at least 1 year or longer depending on if you're as paranoid as me about shitty contractors
Old Nov 5, 2009 | 01:26 PM
Bent = #1
It will probably end up around $500-$600 because I don't believe the first estimate included replacing a rotted piece of plywood. He is coming tomorrow, so I'll know for sure.
He got great reviews online, so I'll have to see what happens tomorrow.
Old Nov 5, 2009 | 02:04 PM
That includes materials? If so that's a good price.
Old Nov 5, 2009 | 02:57 PM
Bent = #1
Yeah it includes materials AFAIK over the phone. I got another quote for $800, so considering this one may end up around $600 it seems like a good deal.
Old Jan 24, 2017 | 12:21 PM
stogie1020's Avatar
Needs more Lemon Pledge
revival...
I have a roof leak. I am guessing I need the entire roof redone.
It's 18 years old, tile, and I think the underlayment is just gone at this point...
20 Years is about the max you can get out of the underlayment in Arizona with the heat and temperature changes (30-40 degree swings each day).
So, what they do here if your top layer tile is OK is they remove the tiles, stack them, repair/replace the underlayment and any base wood that is damaged, and then put your tiles back on.
Anything I should ask the guys who are coming out to give me estimates? Two layers of underlayment?
Old Feb 16, 2017 | 11:19 AM
stogie1020's Avatar
Welp, new roof going on next week. Materials will be delivered this week.
Truthfully, it's just a new underlayment, but since they gave to remove all the stone tiles, set them aside and then replace them, it takes about a week of work.
Scottman111's Avatar
1919
You could have removed the tiles...
Old Feb 16, 2017 | 11:30 AM
stogie1020's Avatar
Are you kidding? They pull them, stack them and then replace them. There are probably 2-3 thousand of them... Plus, they work in sections, not all at once, so they can leave at the end of the day and I don't have an exposed roof/attic.
Hell. No.
Old Feb 16, 2017 | 11:36 AM
1919
Just messing with ya. I've helped replace a few shingle roofs and that's bad enough.
Image doing that job during an Arizona summer
Old Feb 16, 2017 | 12:26 PM
stogie1020's Avatar
I should get a discount for doing this in the winter... The tiles are heavy, breakable and generally a PITA...
Old Feb 21, 2017 | 05:59 AM
dallison's Avatar
registered pw
Those tile roofs are so cool looking. I guess mainly since we don't have many here in PA.
Old Feb 23, 2017 | 11:28 AM
stogie1020's Avatar
Roofers have been tearing up the roof and hopefully replacing the old with the new...
I say hopefully because it occurred to me that once they are done I will have NO idea what they did other than asking me for a check and being up there at 7AM every day.
I mean, once it's done, you can't really see any shiny new roof, you don't get to go play with your new roof, nor do you gaze at your new roof longingly and admire it because it looks just like the old one...
The only indications I have of progress is the amount of stuff being tossed into the dumpster in my driveway. Speaking of which, some ass hat drove by in the middle of the night and tossed a queen mattress into the dumpster! Wait, was the mattress really a part of my old roof? Maybe that was why it was leaking...
Old Feb 23, 2017 | 12:38 PM
Marcelechka's Avatar
Rawr.
Hey Stu -
Depending on the company, you certainly can / should've asked your project manager to allow you to take pictures of each phase and or have them take it for you. I did for documentation purposes in the event we decide to sell and buyer asks. Yes they can pull permits to verify, but, while the job is being completed, it ensures the roofers on top of it since it's being archived.
Just my thoughts.
Old Feb 23, 2017 | 01:47 PM
stogie1020's Avatar
Originally Posted by Marcelechka
Hey Stu -
Just my thoughts.
Interesting idea, and I had not thought of a possible sale of the house. I will have a transferable warranty, though, so hopefully that will be enough.
They are done today, so no real point in having them take any pics...
Old Feb 23, 2017 | 02:06 PM
Rawr.
Neither did we... right until about a month ago, where homes in our development are now closing for damn near double what we paid less than 2 years ago.
Question for us though is, where do you go as any upgrade will cost just as much if not, more.
Wouldn't rule out renting until there's another market correction... but yeah, just a thought.
Mike734
Dec 10, 2021 01:25 PM
SidhuSaaB
May 30, 2020 12:40 AM
thegipper
Sep 28, 2015 01:01 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
spoiler900
Sep 23, 2015 04:41 PM
