Extending an electrical outlet to the backyard?
Just dial 1911
1 Post
Has anyone done this before? I'm basically going to extend an outlet on the back of my house out to the far end of the backyard. This outlet is GFCI. I want to put a 4 outlet box out there (its for a fountain, lighting for the fountain and a low voltage lighting transformer).
So far, I plan on running the wire with PVC, but the question I have is exactly how many wires do I need to run and how? I saw that the two outlets at the back of the house have 2 black wires and 2 white (hot) wires, plus an exposed ground wire. If im going to run a 4 outlet, how do I get the extra wires run? Can I just use some sort of terminal block? Also, what type of wire can I use?
Hopefully someone has done this before and can shed some light. I've searched google for the past hour and cant find anything specific.
Just dial 1911
1 Post
Originally Posted by Ron Burgundy
I just finished it. I ran the pvc to the backyard. Used the 12/2 wiring. Box extender at the house, new box and cover out the in yard, mounted to the concrete wall. Several hours of reasearch yesterday, couple of hours at home depot, and about a days worth of work But it works perfect. I even bought a remote switch to turn the fountain on and off from the house.
Biggest pain was getting the wiring right for the electrical.
Just dial 1911
1 Post
Originally Posted by Scottman111
What kind of problems did you have?
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
