Electrical help
Old Jan 26, 2007 | 04:47 PM
KingsFanPaul1's Avatar
2002 NBA Champs!!!
Electrical help
now I know this probably belongs in another forum but i was hoping to put it here for a quicker response.
We sold our house and will be renting for a couple years. The new house we will be renting does not have over head lights in the rooms. There is a switch in each room thats works for one of the outlets. The lights that I have bought from IKEA are hardwired. Is there anyway that I could convert them so that I could plug it into the wall and then use the switch to turn the lights on?
Thanks in advance.
Paul
Old Jan 26, 2007 | 05:11 PM
savage's Avatar
Engineer
you could hard wire the leads to a line cord and plug it into the outlet. I probably won't be the prettiest install.
Sorta gotta see the setup of how the light mounts and where the outlet is to figure out the best wiring scheme...
Old Jan 26, 2007 | 05:12 PM
jlukja's Avatar
Old Jan 26, 2007 | 05:42 PM
2002 NBA Champs!!!
not sure if this helps at all but this is what it looks like
Product information
Key features
5 halogen bulbs included; no need to buy separately.
Can be mounted to the ceiling or the wall.
Adjustable spotlights.
designer:
Olle Lundberg
Product dimensions
Shade diameter: 2 ½ "
Cord length: 11 ' 6 "
Shade diameter: 6.5 cm
Cord length: 3.5 m
This product requires assembly
environment
good to know
Halogen bulbs get very hot. The lamp must be placed at least 8" from other objects.
Transformer electronic, built-in.
Includes: 11 ft. track and 5 spotlights.
Hardwire installation.
care instructions
Halogen bulb GU5.3 12V 20W reflector
product description & measurements
Base: Polyethylene
Spotlight head/ Transformer housing: Polyamide, Paint
Bracket: ABS plastic
Shade: Anodized aluminium
package measurements & weight
(1 packages in total)
we were hoping we could just screw into ceiling and then run a wire to the side of the wall and then down the wall and into the outlet. I know its not a clean looking install but I am just renting so I dont care. If it was my house I would have an electrician wire it all the way I want.
Old Jan 26, 2007 | 05:44 PM
2002 NBA Champs!!!
so you are saying that i could take the two wires that I am suppose to wire into the ceiling wires but instead wire it into a line cord and plug it in?
Old Jan 26, 2007 | 09:50 PM
NSXNEXT's Avatar
Buy an extension cord and cut the receptacle end off (the non-plug end). Strip the wires and use splices to connect the extension cord to the lighting wiring.
Use ones like the blue one below. You'll need to figure out the thickness of the wire to determine what size splice you'll need.
Old Jan 27, 2007 | 06:50 PM
2002 NBA Champs!!!
thank you
Dec 7, 2020 05:39 PM
Feb 25, 2020 09:57 AM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
joflewbyu2
Oct 8, 2015 11:16 AM
