Is it easy to adjust a sprinkler head?
Old Sep 27, 2007 | 08:50 AM
TBone2004's Avatar
Team Anthracite Member
My neighbor (whom we do not really speak to - perhaps cultural differences?) got a new sprinkler system put in. One of the heads must be pointed at my driveway because each morning it is all wet on the driveway by this one head. Are they easy enough to adjust by hand or is it a big deal to do? If it is easy I will just go outside one night and adjust it. If not I will attempt to explain to them they need to turn it a little. I would appreciate any tips on adjusting it.
Thanks.
Old Sep 27, 2007 | 09:11 AM
pmptx's Avatar
Honda+Blue=My garage
Thanks.
Most have 2-3 inset screws for adjustment of the spray and the rotation.
Net, net is it should just take a screwdriver, but it is a tricky adjustment unless you know the type of head because you could be adjusting the wrong way.
Old Sep 27, 2007 | 09:13 AM
NSXNEXT's Avatar
Obviously you'd need to wait for it to turn on in order to know if it's adjusted correctly.
Old Sep 27, 2007 | 09:18 AM
phil2's Avatar
has Gloryhole Girls in
Its a piece of cake...I had the same problem with my system and I adjusted them myself.
here is how to do it.
http://mikesnaturesown.com/5000.htm
Old Sep 27, 2007 | 10:24 AM
Scrib's Avatar
Administrator Alumnus
My Toro system simply requires a flat head screwdriver.
Old Sep 27, 2007 | 09:03 PM
csmeance's Avatar
it depends on the sprinker and the quality of it, my crappy ones require a screwdriver, but a simple twist of the head will fix it, these are the rotating ones. Tough the heavy duty Hunter and Rainbird 42SA's have a mandatory screwdriver policy as its almost imposible to turn them when on or off without the key. easy way to fix, unscrew the entire sprinker and put it on his lawn.
Mike734
Dec 10, 2021 01:25 PM
ITSJESTER
17
Dec 6, 2018 02:29 AM
Jul 16, 2017 07:33 AM
ceb
ILX
Sep 27, 2015 10:56 AM
