Closed on a lot today. Approximately 3/4 acre (120 W x 270 D). Downward sloped for a walkout basement. Well/septic required. Gas/electric/cable from utilities.
Wife and I are downsizing from a 3400 sq. ft. 2 story to a min. 2400 sq. ft ranch with walkout basement. I have a few ideas of things I want--
- casual Craftsman-ish look
- open floor plan
- 5 car garage (3 x 2)
- 3 season room with a fireplace in back.
- outdoor seating/dining area with a firepit
- janitor closet with charging station
- wired with gigE throughout
- charging area(s) in the garage for various battery powered yard implements
- no formal living room
- just one dining space
- bedroom suite in basement for kids when they visit, live-in caretaker if needed in the distant future
- dog wash in the basement suite
- master suite and in-law suite on first floor.
- large walk-in closet with island/drawers in the center.
- family room for home theater in basement possibly with fireplace
- great room on main floor with fireplace.
- wine refrigerator in the kitchen
- large laundry room with space for ironing board, folding clothes.
- walk-in pantry
Any great ideas out there? Some of the things on my list are handled poorly by our current house (like enough outlets in the garage, and adequate storage for cleaning supplies/tools).
And probably for the price you paid for the land and once you build the house it will still probably be less then a house in California with 1200 sq ft.
Not sure about the welder; I have never gotten into metalwork. The big garage is for 3 cars, detailing, and a yard tractor/accessories.
I will probably have a woodshop in the basement; haven't decided because I haven't used it in the past few years.
If you have any inkling of an idea to get back into woodworking, get a dedicated 20A line run to that room at the very least. If you can, get a sub panel for the shop as it'll allow for expansion. I'm going to have to get a sub panel installed in my garage as I won't be able to use my new dust collector in addition to another tool which entirely defeats the purpose.
Also other thoughts:
- Run 240V to garage for future EV use.
- Run a cable line and power outlet to an inconspicuous central location in the house (under stairs usually) for putting modem, router, etc there. This can also be where all the gigE terminates.
- Run conduits for home theater low voltage cables even if they are empty. Will help tons in the future.
- Sump pump
- Hose spigot inside the garage so you can use it in the winter. Drain also needed in this case.
- Sump pump
i upgraded the subpanel in my garage to a 90a when we did the upstairs addition... it used to only be a 30a for basic electric, but i always thought about one day with an EV, you need at least 50a...
Looking forward to seeing how this turns out. I'm super jelly of your garage size. Shiiiet... that would be a dream come true... but I'd want it in the city, though
Definitely will do a subpanel if I retain the shop; I have a 100A sub in my current shop. My stationary tools are 3HP table saw, drill press, mortiser, band saw, dust collector, planer, jointer, miter saw, lathe.
Home theater... toying with a rack in the mechanical room. Not sure if I need anything more than 5.1 anymore. I am thinking in-wall speakers with only the sub as an external enclosure. Excellent ideas on the wiring and not having the modem location be an afterthought. I will probably have a sizable switch and a PoE injector with a structured wiring cabinet.
Garage will be attached. Probably have a bonus space above it for storage.
Really good thoughts there on having the garage be EV ready.
if you plan on having outside entertainment areas, i'd also run the speaker wire to those areas into your media closets...
Sam's idea or security cameras is also solid... with IP cameras you only need to run a CAT cable since it's all PoE nowadays as well.
-Good idea on 9’-0” ceilings - makes a big difference. Maybe introduce interior transom windows -Generator or backup battery unit? -Geothermal heat pump? -Fire Protection Sprinkler System? -Lawn irrigation system? -Orient the house to take advantage of local climate. Passive summer shading elements that also allow winter solar gain. Evening glare control. -Hot water heater recirculation loop -Heated driveway? Heated garage? - “casual Craftsman-ish look” I picture several gabled roofs – use the additional interior height wisely to keep it ‘special’
- “5 car garage (3 x 2)” Do you mean a 3-car width but with tandem parking? What about a rear garage door for easy access to a side yard?
- “outdoor seating/dining area with a firepit” – Would you do hardscaped / built-in seating at walkout basement level? How about a deck/balcony above at the first-level?
I’m a licensed architect in 3 states, and a licensed real estate broker. From one long-time Azine user to another, let me know if you ever need a test-fit, second opinion, or anything else throughout this journey. Depending on my free time, I’d be happy to help in any way that I can.
I've always wanted to put a garage door to access part of a walk out basement to add an additional stall for a collector car(s) and easy access to bring big crap into the house. This would basically be an integrated basement garage and be a separately insulated space and not part of the living space.
Maybe if/when I build a house I'll do this...
We looked at a model a couple decades ago that had stairs in the garage to a basement door. That would have been sweet for a basement shop. I think a walkout anywhere in the basement will serve my needs for getting lumber and tools in and out of the house with minimal fuss.
Any schedule to break ground, or still in the early planning stages?
Early planning. Working on picking a builder, plan, and financing. Hoping to break ground this summer and move in spring of '19. I have been going through our current house painting and fixing and decluttering. Lots to do there! Almost done with painting the first floor.
... Not sure if I need anything more than 5.1 anymore...
A good 5.1 system delivers a great movie watching experience IMO - the only real benefit to anything beyond that is as a way to get rid of some excess cash :P
I mean, if I'm watching a great movie at home, with a friend or loved one, I've never thought I wanted to stop the movie and say: "gee, I sure wish that sound effect sounded a little higher"
Now, going from just the TV speakers playing back stereo off a VHS tape back in the day, to, a nice 5.1 sound system playing back a 5.1 DTS soundtrack? That is a whole new level to the experience that's entirely worth it if you're gonna enjoy movies at home.
If I was building a nice new house, I think I'd put a couple little robot vacuums and give them mini "garages" to park in I wonder if they have ones that can empty themselves out into a waste bin yet?
Along with the sub-panel, you should have a whole house surge protector installed.
Generator back up
On demand high efficiency hot water supply
Cat 6 wiring, if you go that route.
In wall and ceiling heavy gauge stereo speaker wiring around the house. (kitchen, bedroom, deck, etc) 5.1 surround sound mentioned above is a must.
Wiring for motion detector lights, at minimum above your garage doors. You can do around the house for more security, if you wish.
Central vac for the garage and detail of cars.
The Mrs. and I like pocket doors.
Central alarm
I have three herding dogs. I can just imagine the pandemonium robot vacs would cause.
All colors Benjamin Moore Aura paintPowder Room — DolphinDining room/living room — Boothbay GrayLaundry Room — FusionKitchen — WishFoyer/Family Room — PensiveOffice — Templeton GrayEdit: Fckn auto paragraph feature. How do I kill it?
Do you have advice for performing due diligence on a builder?
Items you may want to know as you compare builders. Hope this helps you narrow the search.
What contract type do they prefer to use and why? 'GMP' Guaranteed Max Price - expect many contingency dollars
Or 'Cost+' you see actual costs and agree to their +%Fee upfront
Contract type and quality of drawings help to avoid costly, unexpected Change Orders during construction
Do they have an exclusions list - are there any building components they choose not to work with/ provide?
Do they offer/ coordinate preconstruction services? (architect/engineers, filing/attaining permits, soil/ environmental testing)
Would they have a dedicated superintendent or field staff on-site? (and not just send their subcontractor trades)
The obvious one is to view their portfolio and get some addresses of past projects.
If you are working with a banker, you can also ask if they've heard of the builder or would recommend one
Are they more of a speculative developer used to only dealing with themselves? Or a custom home builder that regularly also provides customer service to clients?
