A/C not working well at condo
Old Sep 15, 2014 | 11:17 PM
JS + XES's Avatar
I drive a Subata.
Hi guys!
Just had a quick question.
So, my wife and I are living in this condo unit in LA.
Recently noticed that our A/C isn't really working well. Even when we turn it on with the lowest temp setting, the air isn't really that cold.
Is this something that we can fix it pretty easily? or should I just contact our landlord?
Never really had an issue like this before, so just thought to make a thread on AZine.
Thanks!
Old Sep 15, 2014 | 11:45 PM
A SiQ TL's Avatar
check the filter to make sure its not really dirty
if yes , change it
if no, call landlord
and by really dirty I mean so gross that not much air could get through it.
Old Sep 16, 2014 | 01:24 AM
asianspec's Avatar
Needs freon?
I would contact the landlord if anything.
Old Sep 16, 2014 | 11:36 AM
stogie1020's Avatar
Needs more Lemon Pledge
Renting?
Call landlord.
Old Sep 16, 2014 | 06:48 PM
hornyleprechaun's Avatar
Bent = #1
Change air filter
Get an a/c company to recharge the freon
Don't do what I did...
https://acurazine.com/forums/home-ga...ilters-739644/
Old Sep 17, 2014 | 02:50 PM
YeuEmMaiMai's Avatar
first thing to check after your filter is to see if the FAN for the condenser is working as it should. if not the owner will have to replace it. They run anywhere from $70 to about $300 depending upon size HP etc... also if the unit is dirty, clean it out
Old Sep 17, 2014 | 05:21 PM
litesout's Avatar
Oliver!!!
Do you have central air or is this a window/wall unit?
If its a central unit, after checking the obvious stuff go to the outside unit and make sure that the fan is running. I just had to replace the capacitor in mine a few weeks ago. Also, check to make sure the condensate drain isn't clogged. If it is, and if yours has a float switch, the backup of water may be turning off the compressor. Also, look at the coils and make sure that they're not clogged with dust or debris.
If this is a window shaker or a wall unit, the filter and the coils are about the only things you can check. If they're clear, call the landlord.
Whichever type unit you have, if you do have clogged up coils go to your local hardware store and get coil cleaner. Its not that expensive and you don't have to worry about reactions / oxidation of the coils that could be caused by using household detergents.
Old Sep 21, 2014 | 07:47 PM
1StGenCL's Avatar
958 & 991
I'm confused, you are renting and took the time to post this instead of just calling them; best renter ever.
01CLOwner
Oct 9, 2015 01:07 PM
2012wagon
Sep 29, 2015 04:21 PM
acurajj
Sep 19, 2015 03:47 PM
theinsvnity
Sep 10, 2015 10:22 PM
dlknight
Sep 3, 2015 07:54 PM
