View Poll Results: To replace the broken garage door spring...
I can fix it myself. The job is doable for someone mechanically inclined.
13.33%
I should call a pro. This isn't something I should mess with.
60.00%
Whiskers
26.67%
Voters: 15. You may not vote on this poll
Broken Garage Door Spring - DIY or Professional Fix?
Old Mar 19, 2012 | 12:45 AM
thunder04's Avatar
Sweet!
I came home this weekend to a broken garage door spring:
From a quick Google search, I find that there is a mix of "call a professional" and "fix it yourself". What does AZine think? Should I call a pro or attempt to fix it myself? I'm fairly handy if that makes a difference.
If I am to fix it myself, is this a part I can pick up at the local Ace Hardware or Home Depot?
If I should leave it to the pros, anybody have a garage door repairman recommendation for my area (Tracy)?
Old Mar 19, 2012 | 12:51 AM
csmeance's Avatar
use a pro, those springs are under a LOT of tension and can break bones like they are twigs. Call an independent company; usually they have some of the best deals and pricing around. Don't call up sears or a big box co. they are going to rip you off.
Old Mar 19, 2012 | 07:27 AM
svtmike's Avatar
I've always had them done for me, and I am pretty mechanically inclined. It's hard to beat the convenience because it's not that expensive to have them done. I can get one fixed within a few hours of it breaking.
Old Mar 19, 2012 | 07:33 AM
HEAVY_RL's Avatar
This... I'm sure a friend of a friend will know a guy that can do the work.
Old Mar 19, 2012 | 07:55 AM
Nexson's Avatar
-Brian
agreed
Old Mar 19, 2012 | 08:46 AM
doopstr's Avatar
It doesn't appear to be under pressure at the moment. I've never worked on a torsion style like you have. The extension style are pretty easy to replace. I did them myself. If you want to do it yourself I would imagine you can find a video on youtube.
Old Mar 19, 2012 | 10:03 AM
ttribe's Avatar
Originally Posted by Nexson
agreed
Adding my voice in agreement. I had one of these break (sounded like someone shot a gun in my garage) and there's no doubt that the tension on these can make this dangerous.
Old Mar 19, 2012 | 10:15 AM
thunder04's Avatar
Sweet!
Hmm, well, I don't know what to do. The majority of you say to have a pro do it, but the poll is leaning towards Whiskers.
So, uh...I guess the poll is out.
I'll call a pro. I could probably replace the broken one myself, but from what I've read it's recommended to replace both springs (makes sense). I don't want to mess with the spring currently under tension...
Old Mar 19, 2012 | 10:22 AM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
everything I've read said not to mess with the torsion springs, the other ones are easy to replace. I know you can do it, but it's much more dangerous when dealing with the torsion ones
EDIT: Good move
Old Mar 19, 2012 | 10:33 AM
thunder04's Avatar
Sweet!
A repair guy will be out between 11am and 1pm
Old Mar 19, 2012 | 10:41 AM
SuperTrooper169's Avatar
In the Mid-South meow
^ Wise choice. My brother in law's father had one of those springs go through his cheek and break half of his teeth out. The tension they're under is no joke.
Old Mar 19, 2012 | 10:44 AM
thunder04's Avatar
Sweet!
Yikes!
Old Mar 19, 2012 | 01:42 PM
Shalooby's Avatar
Secret Agent
Good choice calling someone. When mine broke I called the hardware store to see if the had them in stock. The guy asked me what color the spring was. When I said "rust" he implored me not to try it myself. His words were somewhere along the lines of "Do Not Fuck With That!" Turns out that the extension type springs are color coded for the weight of the door, and that's what he thought I had.
Old Mar 19, 2012 | 03:46 PM
thunder04's Avatar
Sweet!
All fixed. $255 later new springs and rollers. I don't know if that was a good deal or not, but the customer service of the company was top notch.
The door is much easier to lift by hand with the new springs and is much quieter. I like!
Old Mar 20, 2012 | 01:19 PM
Scrib's Avatar
Administrator Alumnus
$250 isn't bad. I value my life a lot more than the $250, that's for sure.
Old Mar 22, 2012 | 05:21 PM
KaMLuNg's Avatar
agree... i have also only done extension springs.. those are easy... i wouldn't mess with these...
Old Apr 7, 2012 | 08:49 PM
1StGenCL's Avatar
958 & 991
I have the same problem and was tempted to do it. when these break, do chunks fly off? Curious because it sounds like it would damage a car or person.
Feb 25, 2020 09:57 AM
cycdaniel
Dec 17, 2019 10:58 AM
tman570
Jun 11, 2019 07:56 AM
giovane
2G RDX DIY & FAQ
Jul 8, 2016 10:46 PM
gqdabien
Sep 8, 2015 11:41 PM
