BlackAck's House Projects Thread
So, I bought my house 7 years ago, and it's a work in progress. I have a number of rooms that need fixed up. I enlisted the help of my buddy who paints professionally to help me do my kitchen and possibly my 2 bathrooms.
The first and most pressing need was the kitchen. My ex-gf who I used to live with decided that she wanted to paint my kitchen, and did an absolutely horrible job. I don't have any good befores from when I bought the house, but it started off with wallpaper which she removed with a butter knife. In the process, she grooved the plaster severely, especially above the sink and stove where it shows most prominently. On the bulkhead above the cabinets, she simply left the wallpaper glue from the border and painted right over it. She also didn't tape off the edges correctly, so there is paint bleed all over the ceiling, walls, under the bulkhead, etc.
Worse than that is the color scheme that she chose, she wanted to do a 2 tone brick red and tuscan yellow, however the "tuscan yellow" turned out more orange than yellow, and we had to cut it with eggshell off-white paint to try and make it look better, however it didn't help. My kitchen has been this way for about 5 years, and I asked her to move out 4 years ago, so it was time for a change, and I was sick of looking at it every day.
I took lots of before pictures, as we were going to need at least an entire day of prep before we could even think about painting. I also wanted to show just how bad of a job it was.
Here you can see the "back splash" area above my sink that I have been staring at since she painted. You can see the groove marks from the butter knife from where she removed the wallpaper, it's accentuated even more by the dark red color. You can also see the square cut in line where she used a cut-in tool from home depot, and did not blend the paint or smooth it out whatsoever.
The cut in line continues all the way under the cabinetry from 1 end of the wall to the other, here is to the right of the kitchen, you can also see that she painted right over all of the outlets, which I will be replacing as well. You can also notice the paint bleed on the right corner, it looks like this at every edge and corner in the room.
Here you can see the tape bleed from the bulkhead onto the white ceiling, as well as primer that was not painted over at all
I couldn't get a good before of the border glue at the top of the bulkhead, you can kind of see it in this picture, but you can also see more butter knife grooves at the bottom of the bulkhead.
Excuse the spider webs, I cleared them out after I took these before pics. This is the corner behind my fridge. Here you can really see the shitty quality of the paint job. The white ceiling paint bleeds over onto the yellow about a half inch down. You can also see yellow on the ceiling, and traces in the corner of the first orange "tuscan yellow" that she started with.
A better shot of the ceiling paint bleeding down over the wall paint. I actually removed most of this with a finger nail.
Top corner of the bulkhead and ceiling, more paint bleed on both sides, both red and white on the ceiling as well as a roller mark in the corner, and the seam which doesn't appear to have been painted at all. This is the edge right next to the doorway entering the kitchen.
Here you can see where the wet red paint was not allowed to dry before it was taped off, leading to paint removal and more paint bleeding
This is the other side of the room toward the window, the other edge of the cabinets with the bulkhead above. Here you can see more primer that wasn't painted, tape bleed, paint on the cabinets, and the line between the bulkhead and cabinets that was not painted at all.
Some 1960's wallpaper showing through as well in that crevice between the cabinets and bulkhead.
She also tried to patch the edge of the window sill with mud, however didn't sand down the mud and simply painted over it, you can see more of the original orange color here as well.
The window sill/frame was quite a surprise as I usually have the blinds down in the kitchen. There was wallpaper glue all around it, and the plaster was bubbled. This also was simply painted over.
You can also see the first orange color showing through
Sand, sand, patch, sand, thin-coat it all, sand, primer, base.
Good luck.
Also, I love my Wagner sprayer. It puts down such a clean coat of paint it will actually bug you because you're so used to seeing the texture rollers leave behind.
Good luck.
So, I posted the befores to show you what kind of nightmare that I'm dealing with. Here are a few of the prep work.
We had to sand all the painted over glue off the bulkhead. My buddy also sanded the entire ceiling with a pole sander.
We then sanded all the thick cut-in line around the cabinets, and mudded over all the butterknife holes in the plaster and sand smooth.
We also had to sand and patch numerous paint bumps and drips around the room. As you can see in the bottom of this picture, she also had glued up vinyl cove base that had fallen off because she didn't know what she was doing, so I was left with the cove base adhesive at the bottom which I had to soak with adhesive remover and scrape by hand.
Here's the cove base adhesive removed, I got half the room done before my wrist gave out from scraping.
My buddy mudded the whole bulkhead and sanded it smooth, we still have some final sanding left to do, but this is what it looks like prepped.
He also caulked the top edge of the counter tops with painter's caulk.
Remember the bumpy glued window sill? That also got sanded and remudded as well.
^I'm honestly not sure what wood they are. I plan to replace all the hardware and restore them somehow. Like I said, I am waiting to get the paint up before I decide what direction to go. Even when I was taking these pics, I was thinking I wonder what asshat is going to say something about the cabinets. Mikey as usual did not let me down....
Well, we finished the sanding and prep last night and started slapping up the first coats of paint, the ceiling got painted with a white called "Futon" and the red is being replaced with a "Garret Gray". The Gray appears brown when it goes on, but dries more dark gray, it's a nice earthy neutral tone, and looks 100 times better than the brick yourself in the head red.
First step was to do the ceiling.
My buddy who's a professional painter primed the mud patches and painted by hand with a brush, before smoothing over with a roller for the first coat.
As I mentioned, I wanted to see how the cabinets look with the gray before deciding what direction to go with them.
We also replaced all the outlets and light switches in the kitchen since my ex had painted over all of them, and they were rather old.
My buddy who's an electrician helped with that.
I didn't get any finished pictures of the bulkhead yet since it was really late, but we did pull the stove out to see how far down my ex painted, also you can see the old 60's floral wallpaper on the bottom left.
Since she's an ex...
How can people live with such mediocrity? I can't fathom painting/doing house work and being "ok" with even half that quality of work. Hell I painted our living room three times over before I was happy with the perfection.
Makes you wonder...
Looks good man. Not sure about the cabinets and the grey though. And you should run some under cabinet lighting while you're doing this job...
Makes you wonder...
Thankfully my buddy ended up painting for a living and was able to get the paint and supplies that we needed, so that really helped out with the process. Also him knowing what he was doing has helped tremendously as well.
are you doing to do the trim in white? i.e. around the windows? that should give you a good idea of the contrast... with the darker colored walls, i'd be tempted to contrast it with a lighter tone cabinet... if there are too many imperfections when you sand down the cabinets and need to keep it dark, then pop the contrast on the countertops...
White would look good. Especially if you've considered swapping out that linoleum flooring for something else. The room doesn't look too huge and that stuff is really easy (usually) to pull up and replace.
I defintely want to rip up the vinyl flooring, after peaking underneath and seeing wood laminate, I decided to wait and pay someone to do the flooring. I plan to do some sort of tile
Nice update.
AWESOME DOGS!
Seems like the consensus is white for cabinets.
I mentioned that earlier. Ack, In my head I have an ideal of what I'd like my future kitchen to look like and it'll definitely have white cabinets UNLESS I decide to go bold with color. I'm somewhat over dark/light (or any other variation of stain)cabinets. Even espresso is tiring to look at. In a lot of the new builds here they're going dark cabinets with lighter countertops (granite) for contrast. I'm seeing it a lot here which makes me want to go with white cabinets.
AWESOME DOGS!Seems like the consensus is white for cabinets.
It's funny because I showed some pics to my buddy at lunch and he said white cabinets would look good as well
I will start looking into that and see what I come up with, my buddy has a really nice white picked out to do the trim, so I will see if I like that. Also, The 2 tone I will be doing is this gray with a tan called "Sand Dune" Not sure what Mikey was referring to with the 2 grays. The rest of the paint should be going up tonight, more pics tomorrow!
In the straight on pics, the dark grey looks dark grey, but in the angled pics it looks brown to me.
I assumed in the angled pic you showed with the other that it was also a grey that just looked brown in the picture.
The white cabinets would look nice, but they are really difficult to keep clean. When my buddy bought his house we painted his kitchen cabinets white. Within the first year they started to show wear, and now 5 years later they look terrible. The white paint has almost completely worn off on the corners of the commonly used doors and the areas around the drawers looks just as bad. To be fair, we didn't use the special cabinet paint but it was a high quality white.
Prep the cabinets correctly. Use a primer and a high quality white and even a semi-gloss. Use new good hardware and proper door stops. Clean them regularly and they will last.
I want to switch my halogens to a warmer temp, I have super cool white bulbs in there and it doesn't mesh well with the earthy darker tones.
also, if I ever had to do it over again, I would spend a bit more money on an engineered countertop like quartz vs granite... less maintenance and you don't have to worry about having to seal the stone... this will all depend on how much you cook... my wife cooks every night so I find myself sealing our granite countertops every year...
That's their first warning.
