Applying Chauk
Old Oct 22, 2006 | 02:39 AM
bz268's Avatar
Because Of You
Applying Chauk
I was trying all day to re-chauk my bathtop... but... I got a big mess with that white stuff. Just what is the correct way to do it? It seems to be very difficult for this monkey to make the chauking thing look smooth and nice.
Old Oct 22, 2006 | 03:15 AM
Python2121's Avatar
The hair says it all
Originally Posted by bz268
Applying Chauk: I was trying all day to re-chauk ...but... big mess ...white stuff...difficult for this monkey to make the chauking...thing look smooth and nice.
something is wrong with me
Old Oct 22, 2006 | 07:42 AM
Scrib's Avatar
Administrator Alumnus
The secret is using a wet cloth and a bucket of water.
Certainly try not to apply too much, but don't worry if you do.
Take the wet cloth and remove the excess caulk while pressing into the area you want the caulk to be. If you get a lot of caulk on the cloth, rinse it out in the bucket and start again.
You should be good to go.
Old Oct 22, 2006 | 10:14 AM
bz268's Avatar
Because Of You
Exactly!!! I have to squeeeze the white stuff out. And oh man! they do come out alot!!!
Old Oct 23, 2006 | 07:38 AM
NSXNEXT's Avatar
Caulk
When you cut the tip off the tube, makre sure you cut only a tiny bit off. Too big a tip and it makes the mess you described.
Wet your finger and run it along the corner to get the smoothest finish. Periodically wipe off the caulk from your finger then wet it again.
Old Oct 23, 2006 | 01:01 PM
bz268's Avatar
Because Of You
Originally Posted by NSXNEXT
Caulk
tried that. didn't work. It seemed that it required quite a bit of practice for this monkey to do it right.
I also got a DAP CAP. Same thing. Not easy to use.
Old Oct 23, 2006 | 01:36 PM
RaviNJCLs's Avatar
I never had a problem applying it. I just re-did my tub. I cleaned the hell out of it first and it applied OK. I let it dry for about a week before I used it. The joys of having a second bathroom. The problem is that the chauk seems to be coming off in 2 areas. So pissed....I really didn't want to do it again.
Old Oct 23, 2006 | 08:57 PM
DanL's Avatar
You're using latex caulk and not silcone, right? Latex is pretty easy and if you screw up, you can use a wet rag to remove it and start over. But silicone can be a mess if you don't know what you're doing.
EE4Life
Nov 27, 2024 05:36 PM
SidhuSaaB
May 30, 2020 12:40 AM
RLX-Sport Hybrid
3G RLX (2013+)
27
Dec 7, 2018 12:11 PM
thegipper
Sep 28, 2015 01:01 PM
Sep 17, 2015 10:16 AM
