Sealing a front door
Old Oct 10, 2006 | 08:27 AM
fuzzy02CLS's Avatar
I'm moving into a new place. My front door does not hold in/out sound well. There's a gap at the bottom, & around the door. How can I fix this?
I saw these weather strip things that go around the door & something that could go at the bottom at lowes. Do I just need something like this?
Old Oct 10, 2006 | 09:32 AM
pmptx's Avatar
Honda+Blue=My garage
Should be weatherstripped around the frame and the threshold should adjust to seal tightly with the sweep.
Old Oct 10, 2006 | 10:15 AM
fuzzy02CLS's Avatar
Guess I should read up on this stuff since I do not know what a "sweep" is
Old Oct 10, 2006 | 11:14 AM
TBone2004's Avatar
Team Anthracite Member
When you say "gap" - are you seeing daylight and/or feeling a draft?
Old Oct 10, 2006 | 11:29 AM
fuzzy02CLS's Avatar
Feel draft around the door, I can see light from the bottom, & I had my TV at a normal volume & could hear it clearly outside my door from about 5 feet from the door. I can also hear outside sounds clearly inside the house.
Old Oct 23, 2006 | 08:54 AM
fuzzy02CLS's Avatar
So I removed the rubber strip around the door frame & replaced it with a thicker new one. The door seals great now, but it's a little tight now. I have to pull the door hard to close it & the dead bolt takes some force to lock now.
The sound is better, but still not the what I was looking for. I think the door needs to be replaced with something more solid.
Old Oct 23, 2006 | 11:02 AM
pmptx's Avatar
Move the strikeplates back a fraction of an inch and you will have tight and easy to close.
Old Oct 24, 2006 | 07:23 AM
fuzzy02CLS's Avatar
The strikeplates can not be moved, I tried yesterday. No adjustment. I'm fine with it for now.
Old Oct 24, 2006 | 07:50 AM
pmptx's Avatar
Should be able to take a small wood chisel and adjust the opening to move the plate, unless it is already at the stop.
rockyboy
Aug 4, 2024 10:35 AM
Feb 25, 2020 09:57 AM
EE4Life
Sep 11, 2015 10:13 PM
hand123
Sep 10, 2015 09:29 AM
08 NBP TL
Sep 8, 2015 08:49 PM
