Any HVAC experts?
Old Jul 1, 2011 | 09:55 AM
Mike 350Z's Avatar
Any HVAC experts?
Every now and again, my thermostat acts up when I try to run the air conditioner. The unit will click on and run for a couple minutes but then click off, even though the little snowflake still appears (solid, not flashing) on the thermostat’s display which indicates that the a/c is running.
It had been working fine for the past month or so and just starting not working so well yesterday. If I jiggle the thermostat a bit the fan will click on again, only to shut off shortly thereafter, with the snowflake still on the display. So the thermostat thinks the a/c is on, but the fan itself is not running. Sounds like there is a loose connection or it’s just a bad thermostat. Bottom line is the thermostat is not communicating with the a/c unit properly. And it's hot
Of course whenever the a/c guys come to take a look at it, it works fine. Any thoughts? I should note my sister has the same exact model thermostat, and this never happens to her. So maybe the unit is faulty?
Old Jul 1, 2011 | 10:11 AM
doopstr's Avatar
If you are actually hearing it click off then the thermostat is probably bad. Take the cover off to make sure the wire connections are good and you may also want to swap out the batteries to make sure. These things are pretty easy to replace.
Old Jul 4, 2011 | 06:57 PM
Mike 350Z's Avatar
The wire connections look good but I will try swapping the batteries. So far so good today so I'm not gonna touch it now.
Old Jul 11, 2011 | 11:55 PM
rkan121's Avatar
you prob need a new therostat, its a wise choice to fix. Mine is old and drives me crazy, i will be changing it soon.
Old Jul 15, 2011 | 01:42 PM
Mike 350Z's Avatar
Yep, landlord finally replaced the thermostat, so I'm back in business now.
4drviper
Apr 23, 2025 07:13 PM
Jul 16, 2017 07:33 AM
knight rider
Mar 4, 2016 08:59 AM
urbtsx
Sep 27, 2015 09:40 AM
