Sound deadening on the floor panel?
I did something stupid to my 2010 TL SH-AWD to start with... But anyway, here's what happened:
I jacked up the car on the wrong spot and caused a dent on the floor panel right underneath the cockpit. I pulled the carpet and hammered the dent back down. However, I destroyed the layer of black stuff that looks like for sound deadening. It looks like just a sheet about 1/8'' thick glued onto the panel. It's barely flexible but breaks very easily as you bend it more.
I searched the parts store and no luck. Not sure if they just sell it together with the floor panels or not. Any luck I can get an oem replacement for that?
They closest aftermarket match I can find is Evercoat Q pads:
http://www.evercoat.com/productDetail.aspx?pID=50
Thanks in advance!
Thanks in advance!
Try Ensolite, it has a butyl like backing where you stick on top of the hole or even the whole floor if you prefer.
I used this in conjunction with CLD tiles in my prelude on the doors. Great stuff!
http://www.raamaudio.com/ensolite-iu...on-the-market/
Notice the hexagonal shape really confused me and since it was pretty thick and brittle I once thought it was carbon graphite. I think the reason it was so brittle because it was 30 degrees in December. I tried to heat this stuff up and looks like it starts getting more flexible.
Anyway since this isn't even a visible part and there is no significant noise increase I'm not even sure if I will be willing to pull the mats out again and fix it, unless I find a really good match to the original stuff (better with the same hexagonal shape? Am I too picky?)
Thanks again! You are really helpful
If it bothers you in the future, try out Ensolite and cut a big piece out and cover the whole section. I think the hexagon shape are the things under the deadening that produces those shapes, or is it not?
I later figured out the honeycomb shape is actually intentional because it works best for sound blocking. I think any sound deadening material will have it but many in the micro level, not visible like this one. Underneath is bare metal...
Perhaps a good automotive class at the local community college is in order. If you are unable to locate the jack points on your vehicle, you have no business touching that jack.
SidhuSaaB
05-30-2020 12:40 AM
