Sponsored by: DashLynx
Sound deadening on the floor panel?
Old 12-02-2013, 10:32 PM
hyh
hyh's Avatar
I did something stupid to my 2010 TL SH-AWD to start with... But anyway, here's what happened:
I jacked up the car on the wrong spot and caused a dent on the floor panel right underneath the cockpit. I pulled the carpet and hammered the dent back down. However, I destroyed the layer of black stuff that looks like for sound deadening. It looks like just a sheet about 1/8'' thick glued onto the panel. It's barely flexible but breaks very easily as you bend it more.
I searched the parts store and no luck. Not sure if they just sell it together with the floor panels or not. Any luck I can get an oem replacement for that?
They closest aftermarket match I can find is Evercoat Q pads:
http://www.evercoat.com/productDetail.aspx?pID=50
Thanks in advance!
Attached Thumbnails Sound deadening on the floor panel?-img_20131129_154821.jpg
Old 12-02-2013, 11:50 PM
SH6MT's Avatar
Try Ensolite, it has a butyl like backing where you stick on top of the hole or even the whole floor if you prefer.
I used this in conjunction with CLD tiles in my prelude on the doors. Great stuff!
http://www.raamaudio.com/ensolite-iu...on-the-market/
Old 12-03-2013, 01:05 AM
hyh
hyh's Avatar
Question
Thank you very much! I'll take a look at it. To be honest, I doubt the functionality of the original stuff as I barely notice a difference in noise level even on the freeway. It just make me feel better to replace something I've broken with a part as original as possible lol
Notice the hexagonal shape really confused me and since it was pretty thick and brittle I once thought it was carbon graphite. I think the reason it was so brittle because it was 30 degrees in December. I tried to heat this stuff up and looks like it starts getting more flexible.
Anyway since this isn't even a visible part and there is no significant noise increase I'm not even sure if I will be willing to pull the mats out again and fix it, unless I find a really good match to the original stuff (better with the same hexagonal shape? Am I too picky?)
Thanks again! You are really helpful
Old 12-03-2013, 08:47 PM
SH6MT's Avatar
If it bothers you in the future, try out Ensolite and cut a big piece out and cover the whole section. I think the hexagon shape are the things under the deadening that produces those shapes, or is it not?
Old 12-03-2013, 09:27 PM
hyh
hyh's Avatar
I later figured out the honeycomb shape is actually intentional because it works best for sound blocking. I think any sound deadening material will have it but many in the micro level, not visible like this one. Underneath is bare metal...
Old 12-03-2013, 10:28 PM
SH6MT's Avatar
I see, makes since.. So that's why folks with homemade studios put egg cartons on walls haha..
Good luck with what you decide on
Old 12-04-2013, 10:32 AM
Mr Marco's Avatar
Perhaps a good automotive class at the local community college is in order. If you are unable to locate the jack points on your vehicle, you have no business touching that jack.
Marcelechka
Home & Garden
188
09-11-2022 11:53 AM
SidhuSaaB
05-30-2020 12:40 AM
blacktsxwagon
10-27-2015 10:12 PM
95oRANGEcRUSH
09-25-2015 12:50 PM
Quick Reply: Sound deadening on the floor panel?
