Replacing backup light on 2012 TL
Old 01-30-2012 | 07:54 PM
ATL126AM's Avatar
Guys I was looking to replace the backup light on my TL with some LEDs. Would anyone be able to walk me thru the steps.
Old 01-31-2012 | 03:22 AM
potmilkz's Avatar
1. buy reverse led lights (use search button, there are tons of threads)
2. open trunk
3. take off tabs that holds the carpet to the backside of the tail lights, should be 1 tab and a knob to unscrew.
4. bend the carpet back, and get your wrench and unbolt the 3 long bolts that is holding the tail light to the car.
5. use something flat to push the tail lights away from car from inside the trunk. you can use like a flat piece of metal to push against the 3 bolts that is sticking out.
6. take out your reverse light and replace it with led (make sure to not use your fingers to touch the bulb, use a piece of tissue paper to pick it up
7. put the taillights back on the car but do not bolt it back up.
8. do a test run, turn car on accessory on, and put the car in reverse (do not start car, and make sure to pull ebrake just incase you do)
9. if everything good, bolt everything back up
The following 2 users liked this post by potmilkz:
ATL126AM (01-31-2012), dannylee312 (08-26-2013)
Old 01-31-2012 | 05:22 PM
ATL126AM's Avatar
Great thanks for the instructions. I will post pics once completed.
Old 01-31-2012 | 05:36 PM
Treblig's Avatar
While you're at it, you may want to consider changing your yellow signal bulbs to chrome ones. It will eliminate the "egg yolk" look and leave you with a clear lense.
Old 02-01-2012 | 06:43 PM
alienstudio's Avatar
Not to hi-jack this thread, but i got one question. Anyone know how to disable the front parking lights? (also act as the turn signal). I want to disable them so that they only go on when i hit the turn signal switch.
Old 02-01-2012 | 06:57 PM
KB1Spec's Avatar
If you want the front bumper turn signal to be able to just signal, then just cut one of the wire from the socket. So when you have your parking light/headlamp on, the bumper signal will not comes on. It will only comes on when you use the blinker.
Have Fun
Old 02-01-2012 | 08:26 PM
Have Fun
Thanks for the info!
One more question, how do i reach that socket?
Do i have to remove the front bumper or by lifting the front end up and going under the car is enough, and also if there are multiple wires, which one to cut? I don't want to accidentally cut the wrong wire.
Old 02-01-2012 | 08:29 PM
Nick's Ac RL's Avatar
6th Gear
I wouldn't cut any wires. Just saying
Old 02-01-2012 | 08:47 PM
KB1Spec's Avatar
Just use a lift or if your car is not lowered you can easily go under and unscrew some screws and some plugs. Also take out some plugs on the wheel wheel too. Pretty simple. It helps to turn the front wheels all the way to access the wheel well.
If you are in the process to reverse your isntallation like put it back to normal set up you can just buy some connectors.
Old 02-02-2012 | 12:26 AM
djtanveer's Avatar
Some peopl have had success covering one of the connectors on the bulb with electrical tape which is better than cutting the wires.
Old 02-02-2012 | 01:14 AM
Has anyone disabled their parking lights on this forum yet?
Old 02-02-2012 | 01:41 AM
KB1Spec's Avatar
I have....I'll post up a video tomorrow
Old 02-02-2012 | 10:21 AM
el.profe's Avatar
In to see video
Old 02-02-2012 | 11:45 AM
gibbyisgibby's Avatar
I have.
You have to remove several plastic clips and two bolts holding on the front air dam on the bottom of the car then a couple of clips on the wheel well. You can access it from the wheel well (its all in your manual).
The bulb is in a grey adapter, once you remove the bulb from the adapter cover one side of the connection with electrical tape. By blocking one of the sides it will not cause them to come on with the parking lights. You may have to try both sides.
Old 02-02-2012 | 12:15 PM
KB1Spec's Avatar
Another solution is to take out one of the metal pin on the light socket. Save that pin in case you need to put back.
Old 02-02-2012 | 04:11 PM
ATL126AM's Avatar
i dont quite understand what you are talking about here. Can you please explain or provide a picture?
Old 02-03-2012 | 08:48 AM
Since the bulb is yellow when its sitting there, the clear housing will be yellowish because its reflecting the colour of the bulb.
The chrome bulb will make the housing look clear rather than yellowish
Treblig (02-03-2012)
Old 02-03-2012 | 11:25 AM
Treblig's Avatar
Before
after
Old 02-03-2012 | 03:25 PM
ATL126AM's Avatar
what do you guys think about these LEDs for the rear and front turning signal?
http://store.ijdmtoy.com/7440-Single...ee-7440-2n.htm
very bright and clean, yet still OEM look...
Old 02-03-2012 | 03:37 PM
KB1Spec's Avatar
As long as it have a build in resistor...you are good to go!
Have fun
Old 02-04-2012 | 12:03 PM
ATL126AM's Avatar
Have fun
is this absolutely necessary? i didn't see anything needed when i ordered the lights...
do you have a part that you recommend?
Old 02-04-2012 | 02:49 PM
Im pretty sure those have a built in resistor. The comments on the product talk about it not blinking too fast and also it wont throw canbus errors.
I think your fine
Old 02-04-2012 | 06:56 PM
mr_raja's Avatar
Love Guru
How about replacing the turn light bulbs with something like these???
http://www.ebay.com/itm/992-Chrome-Mirrored-Silvered-Amber-Bulb-Bulbs-Set-/290498704740?pt=Motors_Car_Truck_Parts_Accessories &vxp=mtr&hash=item43a3127564
Old 02-11-2012 | 12:09 PM
ATL126AM's Avatar
heres the before and after shot
Old 02-23-2015 | 03:50 AM
Drei's Avatar
Before
after
I want that same look...so will using LED's as turn signals require resistors?
These are the ones I'm looking at getting
2X 1200 Lumens 7443 2538 High Power LED Amber Yellow Turn Signal Lights Bulbs | eBay
mada51589
05-03-2022 09:54 PM
orkoTL
4G TL Problems & Fixes
107
09-28-2017 10:12 AM
bymotion
11-18-2015 12:28 PM
wusty23jd
09-24-2015 12:41 PM
pesobreeze
1G RL (1996-2004)
09-03-2015 01:26 PM
