Replacement Fog Lights
Old 04-22-2015 | 01:10 PM
wreak's Avatar
Has anyone tried any of the ijdmtoy options on the 2012-14 TL's yet?
They have these halo foglights:
Direct Fit 20W High Power CREE LED DRL Halo Ring Fog Lamps
CREE Horseshoe DRL/Foglight combo with cutoff shields:
Acura Honda Infiniti Nissan OEM Fog Lamps Daytime Running Lights
and finally these LED replacements:
OEM Fog Lights with DRL Lights For Acura Honda Ford Subaru, etc
I don't think I've seen anyone using any of these options yet.
Old 04-22-2015 | 01:11 PM
Just get these instead and don't bother with ijdmtoy craps...
Morimoto XB LED Fog lights
Old 04-22-2015 | 01:21 PM
kcarr91's Avatar
+1 i have these and couldn't be happier
Old 04-22-2015 | 02:06 PM
korrupt3dazn's Avatar
What the reason for it not working with 2009-2011? Just the bracket?
Old 04-22-2015 | 02:35 PM
kcarr91's Avatar
something about the 09-11 are oval shaped while the 12-14 are round shaped fog lights
FYI there is a discount (15% i think) on the retrofit source for any acurazine member
Old 04-22-2015 | 02:36 PM
code should be "acurazine". i believe
Old 04-23-2015 | 11:57 AM
wreak's Avatar
Those look identical to the last set I posted from ijdmtoy, any clarity on why the ijdmtoy ones are crap but those aren't?
Old 04-29-2015 | 02:49 PM
wreak's Avatar
Well I did a bit of research on the Morimoto LED foglights and I'm very impressed, this is a picture someone took showing the cut off and brightness with just the foglights on...
Very impressive.
Old 05-26-2016 | 11:32 AM
Jmagid's Avatar
Did you end up getting the ijdm one's? I purchased the horseshoe version #2 but haven't installed yet. Was hoping to see a picture first.
Old 05-26-2016 | 11:48 AM
If you bought it already, why look for a picture, why not just you know, install it and see it for yourself IN PERSON
i mean, you can take a picture of it after the fact an dlook at the picture instead of you want
Old 05-27-2016 | 11:50 AM
Jmagid's Avatar
I'm curious if he liked them, if they were crap as some pointed out and how bright they actually are. I am on the fence about returning them. Probably the same reason you see many ask for pictures of other lighting before installing their own.
Old 05-27-2016 | 12:00 PM
Most people also wait for pictures PRIOR to buying...
Marmbo
4G TL Problems & Fixes
09-21-2015 10:39 AM
theinsvnity
09-10-2015 11:22 PM
cruisingnycfl
09-02-2015 01:11 PM
prox
5G TLX Problems & Fixes
09-01-2015 03:03 AM
ptbarnett
3G RLX (2013+)
08-30-2015 01:39 PM
