Sponsored by: DashLynx
How much brake fluid needed for flush
Old 04-08-2018, 09:44 PM
Mak P's Avatar
Here says 3-4 quarts, but Acura/Honda doesn't sell quarts, they sell 12 oz. 4 quarts = 128 oz, so I'll need about 11 of DOT 3 brake fluid. Would just like a confirmation if my calculation is off
Old 04-09-2018, 06:47 AM
Received 16,260 Likes on 11,971 Posts
you can use any brand dot 3-4.
if you're buying 12 oz bottles, buy 5.
Mak P (04-09-2018)
Old 04-09-2018, 10:28 AM
Anicra's Avatar
Geeze I just bought 2 32 oz Honda Fluid on Ebay, crap I need to make sure it is the same. err NM they do https://www.bernardiparts.com/Honda-...8798-9108.aspx
Old 04-09-2018, 05:16 PM
VanyDotK's Avatar
You should only need about 1L or 1.5L to be on the safe side.
Old 04-09-2018, 07:38 PM
KarKraze's Avatar
5 bottles @ 12oz , as "Justnspace" said.
I changed my entire brake system last Summer and that is how many I used .
Mak P (04-09-2018)
Old 01-23-2020, 11:13 PM
mrphilipanderson's Avatar
Is this process easy? I need to change m brake fluid.
Old 01-24-2020, 05:06 AM
WDPanda's Avatar
Get into the habit of changing a good portion at each brake job
Old 01-24-2020, 01:42 PM
csmeance's Avatar
Received 1,989 Likes on 1,412 Posts
Buy either the 1 person brake bleeding tool/attachment or the hand vac pump and you can do it fairly quickly. I've been using ATE DOT4 fluid from this site since it's fairly priced and great! I bought 4 for free shipping and used 1.5 -2 Brake fluid containers for each car. You should be changing it every 2-3 years at a minimum!
https://www.fcpeuro.com/products/amb...-dot4-dotamber
ATE DOT4 type 200! You can go to the auto parts store locally and pick up some Pentosin DOT4 fluid but the ATE is going have higher boiling point than Pentosin Brand DOT4.
Don't worry about LV (low viscosity brake fluid), it's meant for euro cars.
chayos00
03-29-2021 09:14 PM
boorah623
10-10-2016 06:30 PM
RDXturbo07
1G RDX DIY & FAQ
05-31-2012 10:04 PM
curls
09-16-2006 10:04 AM
bluesman78
05-15-2006 09:56 PM
Quick Reply: How much brake fluid needed for flush
