recommended tensioner brand?
Hi all,
New to the forum. It's great to have a first gen tsx community!
I have a 2006 Acura TSX with 136k miles and things are beginning to fall apart. I noticed my tensioner pulley rattling a bit when I spin it so I will be replacing the entire tensioner while I am at it. I was hoping to get a recommendation on a good and reliable brand for the tensioner. Can anyone let me know about some of their good/bad experiences?
much appreciated.
much appreciated.
entrqpy (01-02-2019)
I am very weary of the bearings used in aftermarket pulley & idler wheels. The tensioner itself is probably good for the life of the engine and it's the wheel bearing that wears. I usually change the wheel only with an OEM part. But be aware, if you change the wheel only there is a nut on the back of the tensioner arm that holds the wheel. Put your finger on the nut to hold it while you remove the bolt otherwise it could fall and be difficult to locate.
thanks for the input everyone. I went ahead and went with continental elite for now. I do not think I will be keeping this vehicle that much longer, so hopefully it lasts me a few years.
I had to remove the pulley to get to the bolt that mounts the tensioner and I found that the bearings are made in China... hoping they did a nice job. If not, I can just change the pulley wheel next time.
I decided to replace the entire tensioner because when I did the "spray bottle test", I would hear a obnoxious squeal and I read that it is possibly due to a loose belt.
Will let everyone know how everything goes. Thanks again for all the input!
Hi all,
much appreciated.
much appreciated.
I would go OEM for this one. When I bought my car used the belt was chewed up and had already destroyed the hood liner. I replaced the belt and it kept skipping off the pulley. The pulley bearings were tight and sounded fine so I replaced the whole tensioner and pulley even though the marks were within tolerance. A new OEM tensioner and pulley fixed my issues.
pf100
1G TL (1996-1998)
06-08-2017 06:06 PM
02tlnate
11-20-2014 01:22 PM
InFaMouSLink
08-20-2013 01:04 AM
MrTee12
2G TSX Performance Parts & Modifications
26
10-20-2012 10:53 AM
