Need to connect to tach wire
Old 09-06-2010, 11:10 AM
9th Gear
spudsmac's Avatar
Hey, I'm installing a Viper 5901 and have problems with the remote start part. It just keeps cranking and doesent know when the engine is started. I want to hook it up to the tach wire, but can't seem to locate the ECM. I know it's in the center console on the passenger side, but I can't figure out how to remove the ridiculously large piece of molding that's covering it up. Any advice on how else to get this to work. Virtual tach is being worthless right now. Any help is appreciated!
Old 09-06-2010, 03:02 PM
JTso's Avatar
The ECU is relatively easy to get to. Just use the link below as reference.
http://hondata.com/downloads/tsx_ecu_removal.pdf
Old 09-06-2010, 03:17 PM
9th Gear
spudsmac's Avatar
Thanks!
Old 05-14-2015, 05:55 PM
9th Gear
spudsmac's Avatar
Ended up connecting it to the ignition coil wire in case anyone else is trying to fix this issue. Didn't do fuel injector since I didn't want to risk it firing inadvertently and damaging the piston.
navtool.com
3G MDX (2014-2020)
32
01-20-2016 11:43 AM
navtool.com
31
11-16-2015 08:30 PM
SUPRMN84
10-07-2015 09:46 PM
27trains
4G TL Problems & Fixes
09-30-2015 09:44 AM
Quick Reply: Need to connect to tach wire
