Just bought 2004 tsx with high mileage
Old 08-11-2019 | 03:11 PM
jaypark's Avatar
Question Just bought 2004 tsx with high mileage
Hi guys! I'm new at this forum so hopefully you guys don't go too mean on me for asking questions...
I just bought a 2004 Tsx 5AT with 234k on, did fluid changes. One of my friend suggested me to do transmission flush by adding and draining few times. I just got done with second adding and my transmission is whining....
Well it's not grinding at all but whining also I can see when it's cold it doesn't want to shift fast but once it's warmed up, the car shifts okay no grinding or jerking. This noise is killing me.. does anyone have a good solution for this?
would it help if I change the filter?
Old 09-07-2019 | 01:05 AM
voiddweller510's Avatar
3rd Gear
Make sure that you're doing it on a level surface after driving the car and waiting 15 minutes for the transmission to cool down. Verify that you're using the correct spec'd fluid. If you're not sure what to use, go with OEM Honda/Acura fluid.
In some rare cases, you may need to use a vacuum pump to get all the fluid out and refill it. I don't recommend this, but my father had the same issue with his Pilot and using the vacuum pump at the shop to remove all the fluid and then adding new fluid fixed it.
Midnight Mystery (09-17-2019)
Old 09-16-2019 | 11:37 PM
cherubino's Avatar
version 2019
> 2004 TSX 5AT with 234k
wow, I just gave away to young relative my 04@83K
why did you go for such high mileage ? I hope it was the owner paying you to take it....
Old 09-17-2019 | 12:33 AM
Midnight Mystery's Avatar
Null and proud of it
You gave away a car with 83K miles?
I would have gladly given you $7K for it if it was clean.
Mileage isn't that big of a deal. I have 268K on my 2007 RDX and put about 40-50K on it every year.
Old 09-17-2019 | 01:36 AM
cherubino's Avatar
version 2019
yea, to nephew going to college. I promised the kid couple of years ago. Told him to take good care of it and pass it to his bro after college. Should be about 120K then.
Taken last week after detail job:
https://imgur.com/eCWN7tg
Old 09-17-2019 | 01:49 AM
Nice! Even has the ASpec lip!
Old 10-20-2019 | 05:51 AM
hondeducation's Avatar
dang... that was a nice gift to your nephew!
high mileage automatic TSXs i dont have much experience with. is there any metal shards or anything in the tranny oil when you drain it?
Old 12-18-2019 | 02:36 PM
Simba91102's Avatar
Old Guy
Yeah, that kind of mileage will scare off most people. I'd guess you got the car pretty cheap. Though it's considered by some (many?) to be akin to "an old wive's tale", there is some validity to the advice regarding older transmissions "if the transmission fluid has never been changed, or if it was forever ago, don't change it now". Short explanation is because as the fluid ages (so gets "used up") the transmission gets used to the older (now thicker) fluid. New, clean, thin, fluid is a shock to system. True? I don't know; pick a side of the argument. That may be what you experiencing though. The AT in the TSX, if properly maintained, is fairly robust. Maintenance only means fluid changes though (although there is an external filter for which there's no service schedule, but it's accessible and you can change it if you want to). All you can really do is a drain an fill on these transmission (no power flush, and use ONLY the correct Honda ATF). You're only changing a third of the fluid (3 quarts) at any one time. The usual schedule is do it every 30K miles, that way you're performing a complete fluid change every 90K miles, which is the interval if I remember correctly. I have an 07 with 240K miles on it (original owner) and have followed that schedule (more or less) starting at around 60K miles. The transmission pretty much still shifts like new (though I'll admit I have no memory of how it shifted 12 years ago). Feels as good as ever though. The trick to racking up trouble free high miles is maintenance, and I've taken care of the care since new. Sell it? Well, I tried last year, and couldn't give it away (literally), so I still drive it, granted, locally. They're a really nice car. Good luck with yours, and hope you can get the tranny to quiet down.
Old 01-08-2020 | 12:10 AM
zreizzles's Avatar
6th Gear
RIP.. chances are you got swindled...
Skeet33
07-31-2018 11:16 AM
Cashtro04TL
11-15-2017 11:32 AM
BlkwidwAk
05-12-2012 11:55 PM
sateesh
1G TSX Problems & Fixes
01-26-2009 06:32 AM
Quick Reply: Just bought 2004 tsx with high mileage
