RL Section Ramblings
#41
Received 2,328 Likes
for those with a '04 RL, does your center armrest open from the driver's side instead of just up? also, is the height adjustable? does anyone know if it'll fit an '02? my '02 only opens up and that sometimes bothers me because all my coins or whatever that is small would slide out the back.
I don't think its height adjustable, its been a couple years since I've driven one though.
I would assume it would fit
#48
The Box
Went on a trip to Chicago again this weekend. 5 people in the car and full trunk of groceries on the way back. 200 mile trip, will fill up tmrw morning and see how the mpg were. I was pretty conservative the whole trip, kept it 75 and under.
#50
I got 25 mpg going to California and back. Did 72 mph most of the time with several mountain passes.
#51
The Box
The best I've seen so far was 21.xx
I didn't have time to fill up this morning so it may be skewed a little.
I gotta admit with all that weight in the car, the RL would look awesome dropped!
#56
The Box
All these good mpg's are from trips to Chicago. Hopefully I can stop going every weekend now and get back to a normal routine in life...and save some miles on the RL.
#58
VSA is probably a bad sensor somewhere. Get the service manual from pdftown.com for the RL and it will tell you how to pull and read the code.
hows the maintanace on the car? Need of a tune up maybe?
#59
Dealer told me the yawn sensor is one possible problem but the part here in Canada is $1200 and they dont gaurnatee the fix. I can live with it for now just thought I'd put it out there for ideas on fixes.
fluid changes are done frequently but have not had the plugs changed in long a while - I guess that could be the cause of the smell
#60
the yaw sensor? I think the only yaw sensor is in the Nav unit in the trunk and thats completely seperate of VSA.
A common problem in Legends is a faulty sensor on one of the wheels. The rear I believe. You could have those checked out. The service manual will also show you how to troubleshoot or check sensors I beleive.
#61
Yep, vehicle speed sensor or something similar.
#62
btw..is there a way to reset those VSA lights ?
#64
dealer is of no help - they want to charge me 1200 dollars and not gaurentee the fix(???). I tried disconecting the battery but it did not reset the lights.
#65
DTC Clearing
1. Press the parking brake pedal.
2. Push the VSA off switch, and hold it, then turn the ignition switch ON (II).
3. Hold the VSA off switch for 3 to 5 seconds, then release the VSA off switch.
4. After 3 seconds, the VSA activation indicator blinks 4 times. It means that the DTC is cleared.
5. If the VSA activation indicator stays on, replace the VSA modulator-control unit.2. Push the VSA off switch, and hold it, then turn the ignition switch ON (II).
#66
look on pdftown (I think) for the RL service manual. See if you can do it yourself.
Theres a service check connector under the glovebox that you can use to pull the codes.
Oh and that yaw sensor the service manual says its in the trunk you need to remove the cover behind the back seat and the lid that covers the spare to get to it.
This is how to pull the code I beleive.
Look for that service manual it will help alot.
DTC Indication
NOTE: This operation can also be done with the Honda PGM Tester.
1. Connect the SCS service connector to the service check connector (2P) under the glove box.
2. Turn the ignition switch ON (II).
3. The ABS indicator comes on for about 2 seconds and goes off. Then it will indicate the DTC.
NOTE:
• If the DTC is not memorized, the ABS indicator will go off for 3.6 seconds, and then come back on.
• If the ABS indicator stays on, troubleshoot for ABS indicator does not go off (see page
NOTE:
19-213).
4. Turn the ignition switch OFF, and remove the SCS service connector.
NOTE: The Malfunction Indicator Lamp (MIL) will stay on after the engine is started if the SCS service connector is connected.
Conditions for DTC indication:
Vehicle speed is 6 mph (10 km/h) or less.
The SCS service connector is connected before the ignition switch is turned ON (II).
The brake pedal is released.The SCS service connector is connected before the ignition switch is turned ON (II).
#68
Ive had it for a little over a year and half now.
I'm use to working on non standard Honda platforms. lol Have you ever seen a picture of my other No aftermarket support Honoda?
#70
The Box
My pops has been driving my TL since I don't and I'm picking it up tomorrow morning to take some pictures of it rolling over to 250K It's at 249,921 now.
#72
The Box
Yup it's the 2.5 I5 with a 4 speed trans. Been in the family since 1999. Got it with 124K miles, ran from Milwaukee to Louisiana so it was all hwy miles, company car with all maintenance done.
I can imagine the hatch being difficult to mod...
When I had my first TL (beige), I was having a tough time finding any parts for it, it was all $$$ stuff from Japan and I couldn't swing that in high school working at a car wash so I just dropped it, put rims on it, tints, tv, stereo, grill, exhaust and called it a day. That was 8 years ago and there still isn't much aftermarket for them.
#74
cool
there's a guy with a 2nd gen Legend coupe that hit 400k not to long ago and his car is mint. Hope that's me one day.
on a side note I just noticed that there's a "Guided missiles and space vehicles" category in the nav. Now I can get my guided missles. Lol
#75
it's no secret why hondas (and toyotas) are ranked so high in quality and durability (the older models, of course)....they just keep on going and going and going.
#76
Question for the random question forum..
I can't seem to find performance mods other than a good ol K&N filter. Can anyone point me to a place where i can make this lumbering 3.5 breathe easier? Intake? AEM parts to use from another Honda/Acura? Thanks...
#77
The Box
91-95 Legend parts are almost bolt on.
look for cai with VSA for a Lgend.
OBX haders will bolt up, but I believe they Y pipe might need some changes in the RL.
Alot of Legend parts are almost drop in on the RL
